1 - 3 of 3 Posts
2015 Dodge Durango Limited 3.6L
Good afternoon all,
My Durango has 130k miles and has been making a clicking sound while running (top of engine). It idles a little rough when stopped and in “drive”, but not rough while in “park”. Not rough enough to die, just enough to annoy.
No engine light, just clicking and a little rough. Acceleration is a little slow and lagging at low RPMs. Usually lags around 1500rpm when accelerating, but is fine when it gets to about 2500rpm.
Any ideas what it could be?
Worse case would be a roller rocker which the bearing has gone bad that then prevents that valve from opening properly and if left will eat up the cam lobe.
Or maybe just a dirty injector....hard to diagnose over internet.
Good afternoon all,
Could be be this.
NHTSA ID Number: 10187058
Manufacturer Communication Number: S1709000010 Rev.
Summary
Customer complaints may include abnormal engine noise, rough idle, lack of power, misfire. Upon investigation, it may be found that there is excessive camshaft lobe wear/lifter wear (roller failure) on one or more cam lobes and that camshaft/lifter replacement is necessary.
88 Affected Products
1 - 3 of 3 Posts
