2014 Durango SXT - LED Daytime Running Lamp Upgrade??
84K views 84 replies 41 participants last post by  DaisyDurango
Hello everyone. I don't believe I'm the only one that is wondering this but there has to be a way to activate or upgrade to enable the LED daytime running lamps (DRL) on the SXT models. I can see that the strip is there but it's currently only available on the Limited, and Citadel models.
Hoping a dodge service guy chimes in and lets us know what the magic is on this.
All advice is greatly appreciated!! :D
#40 ·
I think i'm smelling class action lawsuit. Isn't their a name for that kind of lawsuit?
#42 ·
I honestly don't recall ever reading that the sxt plus package was coming with DRL. then again I don't care for them. Yes they look nice but i'd rather spend my money on something better like a CAI or exhaust system.
#44 ·
the only other place we could have probably heard it was on the webcast from one of the CEO's from dodge when they introduced the 2014 Dodge Durango at the Detroit or N.Y auto show
#51 ·
When I bought my Durango (2014), the dealer told me the headlight lense can be replaced should it ever break due to a rock etc hitting it. This was apparently something he was using as a selling point, but I didn't think much about it at the time. Now I'm wondering if there is any truth to that? If that lense can be removed, the adding an aftermarked LED strip to these would be fairly easy.
Anyone know if there is any truth to the lense being replaceable and coming off easily? I haven't tried looking as I just now remembered and thought of this.
#52 ·
It's headlight assemblies as a whole not just lenses
#53 ·
Thats what I thought. He said he had a rock go through the light on his new ram, and they replaced the lense and that the dirango had the same kind of headlights. In the back of my mind if figured he was full of crap, but wasn't sure. or that vehichle really is different, either way, doesnt help us.
#63 ·
Well, if you look at the link, you'll see that you have to connect a wire to each side blinker, and also a wire to the headlights, so they can go off whenever you put any side blinker or turn on the headlights. I already bought one, so when arrives I'll update how it works.
Regards,
Marco.
I'll be interested to see how it works out. At the moment, I don't have the ability to view ebay, so I can't see what's in the link. I'll check it out tonight.
#65 ·
Added LED DRL
I used an existing fuse (f95) this the camera parking assist fuse. This doesn't turn off with the blinker, but the LEDs are only on with the durnago is in the "run" mode. I don't think that they interfere with the blinkers, they are not as bright at the factory ones.
I used the Alpena 77015 White 28'' LED Litz Strip from amazon, I think they are the same ones that was at the beginning of this post.
When I installed them, I attached them to the bottom of the headlight assembly. When I removed the bumper, I cut down the black plastic ribs under the headlight assembly to get just a little more room between the bumper and the headlight. The leds are a bit fragile so don't try the jam the bumper back on.
this is a link I found to remove the bumper. DIY: Bumper/Head Light Removal - DodgeForum.com
I hope this is helpful to someone.
here are a couple of my images.
#66 ·
drls feature activated
great news guys,
I went to my dodge dealership today and had the drl feature activated in my 2015 Durango sxt. the manager had to contact dodge to have the drl feature added to my vin number and when that was done the tech activated the feature. the tech stated that depending on the models like the r/t and sxt rallye you do not have to move around the pins in the headlight harness. in my sxt the headlights were in the drl function then he moved two pins around and now the led strips are the drls. you would have to get a set of headlights that have the led strips. I will post pics soon.:-D. the tech stated all 2014-present Durango come pre wired to run drls once activated.
#67 ·
great news guys,
Hey there! Probably a dumb question, but would be able to physically tell if the headlights does have the led strips or you'd have to go to the dealership and have them check? I have a '14 sxt.
#82 ·
I did the LED strip light at Auto Zone on mine and it looks great. We got the 12” and they look nice. For now we wired them off the ignition but are going to look into the turn signal relay too. It was a 40 dollar Kit because we needed the black backing ones as my Durango is the maximum steel color, but a neat little upgrade... slid right in between the bumper and the light (used a squirt of armor all to make it go in easier!).
