1 - 5 of 5 Posts
have a 2013 rt with abs light and traction light on i replaced all 4 wheel speed sensors and light still stays on and tips or tricks to help out new to the durangos thanks
Get the code(s) read. Otherwise you're just throwing parts at the problem.
As DuRon says, pull the code(s). You will need a reader that can do ABS. Not all of them can. Follow that up with a battery disconnect reset. Maybe your light will clear if the faulty sensor being changed was the issue.
Discussion Starter #4
getting a mactool reader tomorrow and will let yall know and i will try the reset too
Silly question, but did you check the fluid and try bleeding the system? Its common for an air bubble to trigger brake sensors.
1 - 5 of 5 Posts
