1 - 3 of 3 Posts
Putting new bearings/seals in the 8.25 rear axle.
I did strip everything off the axle to clean them up.
I can not find (googled) the torque specs for the 8.25 rear, specifically:
The 4 larger bolts that hold the brake bracket to the axle flange
The caliper to the bracket
The big bolt in the center of the diff cover that holds the "cross bar"
Thanks,
Nick
Nicka:
Welcome to DDN.
From my '04 factory service manual:
Rear caliper to adapter bolts 11 ft lbs
Rear caliper adapter to axle flange bolts 100 ft lbs
Watts link to rear axle locating bolt 160 ft lbs. It also states that a new bolt should be be used for the Watts link bolt, or if not, use Loctite 242 on the threads of the old one.
1 - 3 of 3 Posts
