@blazz81 did you solve the MDS stuck in “on” mode, or determine a test for it?
I replaced the solenoids, put in fresh oil, and had issues with a pinched oil temp sensor. After fixing the wire, I lost all throttle response. After clearing codes and resetting the PCM, I had a solid 20 mile drive running great. Then failures started on every drive. I tested each solenoid, and they all seem to turn on and stay on.
I’m thinking I have a bad PCM at this point, but would like to know how to test for the MDS off signal to be sure.
Thoughts?
Thoughts?
