2006 Durango limited 5.7
P0304..misfire cyl 4
P1414.. reactivation control performance cyl 4
Hello I need help with this one my Durango started running ruff the other day. I scanned and got just the two codes.
I have replaced the MDS solenoid and oil change/flush. I also visually checked the wires going to Mds they looked fine not burnt or anything.
I’m still having the same problem. It’s running on 7 cylinders. With same two codes popping up..
according to my scanner cylinder 4 MDS is activating all the time.
After searching around I can’t find any information other than replacing the solenoid which worked for most but not for me.
Any help would be MUCH appreciated
Thank you..
Thank you..
