1 - 3 of 3 Posts
I have a 2004 Limited, leveled out, even slammed some 35's in there with no problem. I want to do a suspension lift but there are none available. Could I make my own by getting bigger shocks and springs? Or welding a block between the spring and the axle? How would I go about doing the IFS? I want anywhere from 2-4 inches of lift. Body lifts are an option but if I can do a suspension lift then I'd like to go that route. I can't find a body lift for the 2nd gen Durango's anyway. Are there any body lifts that would work but are labeled as Dakota or Ram?
If your a strut front end, they make strut tower spacers to give some lift. taller springs for rear work. may not need to change shocks
Could you possibly post a link to these tower spacers? I'm sure a lot of stuff out there would be compatible with the Durango but is labeled as either Dakota or Ram.
1 - 3 of 3 Posts
