1 - 20 of 20 Posts
So i got 297,950 miles out of my 04 Durango and BOOM 🤣😂. Decided on a new engine and transmission vs a used vehicle with high mileage. 14k gets me a new engine and transmission installed 😎. I want to use it for minimal town driving but mostly camp and trailer pulling. Our trailer is 5200 dry and 2000 gear capability, so not towing over 7200 lbs. from the specs I’ve read, 3:55´s (which is what’s in it) will do 7,250 and a set of 3:92´s will do 8,750 lbs towing. Getting max towing is my goal. With that, questions:
1 Do I change both front and back gears to match (3:92’s)
2 Do I assume the front is 3:55´s as well?
3 Should I put in heavy duty axels to help strengthen the rear end?
4 I got the new trailer and had 275,000 miles on it. No way could I do mountains. Will I if I do all this work?
5 Any other suggestions to help with towing capacities?
Build Sheet says:
Lock-Up Torque Converter
205MM Front Axle
3.55 Rear Axle Ratio
Corporate 8.25 Rear Axle
Thank you for any help I can get 😎
HH:
Welcome to DDN. Wow, that is quite an investment for an 18+ year old D.
The big question here, is does your D have the factory tow group? If not, then you are limited to 2000 pounds as shown below.
Trailer Towing(a)
Drive
Engine
Axle Ratio
GCWRb
Maximum Trailer Weight(b)
2WD
3.7 L V-6​
3.92​
8600 lbs. (3901 kg)​
3700 lbs. (1678kg)​
4.7 L V-8​
3.55​
11000 lbs. (3952 kg)​
5900 lbs. (2676kg)​
3.92​
12500 lbs. (5670 kg)​
7400 lbs. (3357kg)​
5.7 L V-8​
3.55​
7400 lbs. (3357kg)​
3.92​
14000 lbs. (6350 kg)​
8950 lbs. (4037 kg)​
4WD
4.7 L V-8​
3.55​
5800 lbs. (2631kg)​
3.92​
7300 lbs. (3311kg)​
5.7 L V-8​
3.55​
7200 lbs. (3266kg)​
3.92​
8700 lbs. (3946kg)​
(a) Maximum trailer weights are rounded to the nearest 50 lbs.(b) Maximum Trailer Weight = GCWR minus Curb wt. minus 150 lbs. (allowance for driver)NOTE: All the above ratings are valid with Trailer Tow Package only.
All the vehicles are rated to tow a maximum of 2,000 lbs. without the Trailer Tow Package.
Re the 3.92 gear, installing those (both front and rear are required with AWD) will help, but you still won't have the HD cooling, etc that the tow group includes.
Discussion Starter · #3 ·
Thank you…. Yes it’s a factory tow set up, I ran the build sheet and bought it new. My wife doesn’t want to give up the vehicle and at 14k investment, I have no car payments and new running gear 👍. This will get me by for 3-4 years before I get a new Ram 2500. 60-80k for new trucks is rough lol.
OPTIONAL EQUIPMENT
Prem Leather Trimmed Bucket Seats
Slate Gray Two-Tone
Heavy Duty Service Group
Skid Plate Group
Trailer Tow Group
Mutually Exclusive Package
750 Amp Maintenance Free Battery
Traction Control
So by reding your chart (might be my iPad) looks like I can do 8700 lbs with the factory tow group, and the 5.7 Hemi correct?
when I change to the 3.92’s how do you think 7200 lbs of trailer will do in the mountains?
and thank you, the help is much appreciated 😎
Ok on having the factory tow group. By the chart, you pick up an extra 1500 lbs by switching to the 3.92 gear.
As far as towing experience goes, I don't tow very often. There are other D owners here who tow more frequently, who will chime in.
I recently picked up a fairly decent older 16' tandem axle trailer. It weighs 1900ish pounds, and will haul 5000. I can't see hauling more than 2-3000 pounds anyway. I have updated the trailer with new LED lighting. The last thing on my list, is to install a brake controller into the D, so I can make use of the brakes on the trailer's front axle.
Discussion Starter · #6 ·
Thank you…. Yeah the trailer brakes make a world of difference. I added them in when we bought our trailer. On one trip coming home I felt the trailer pushing me hard as I came up to a signal light. Pulled over and saw I forgot to plug in 😬. Won’t do that again lol…. New trailer owner fails 🤷‍♂️
No way in hell would I put 14 grand into that old a vehicle. You're nuts as you'll never get it back out of it.
Discussion Starter · #8 ·
Well, I guess that’s a matter of both choice and opinion…. I’m not looking to get it back out of it. I’m looking at logging miles as we love the car. I’m looking at not having car payments. I’m looking at a vehicle that we enjoy and want to keep. I’m looking at a vehicle that is safe to give to one of my grandkids to learn on and drive to school safely in. I’m looking at a vehicle that will pull my trailer until that time comes. I’m looking at what I can buy used for 15 grand that would compair to it and with all of that said, I’m 60 years old and an $800 a month car payment for a new vehicle is not my thing right now. I’d rather put that $800 a month towards my retirement…. Now when you look at it through my eyes, being “nuts” isn’t in the picture… but thanks for the input
Keeping it in the family is a great idea but do realize that all the other things that will go wrong on an 18 yo 300K mile car will make it a burden on anyone else. Just read through the struggles people have with DDs in the Gen 2 forum and you might realize how this isn't a good idea. Heck, you might get some of those impossible to find problems yourself after you drop the 14K and then you're stuck. I completely understand the dislike of the $800 payment but why do you need a new DD when you can get a good used one for less and combined with your $14K down payment I'd bet you'll be around $400 for 5 years. I am in the same boat and we decided to not buy a second DD right now, especially since we still have a payment on the current DD. We are also trying to build up the retirement and we realize how hard it is to do it with a payment but I would definitely way the future of this one against the future of a newer vehicle.
All depends upon the quality of the work IMO which will determine any future problems....and at least he knows the vehicle history as compared to buying a used vehicle which you don't know how it was treated.
I'd lean to towards repairing what I have.
BTW, towing with 3.92's is much easier on the drivetrain.
Given the current absolutely stupid car pricing at present, I think I'd also lean towards fixing the old girl up as long as the body and frame are in good shape. Unfortunately, here in our SW Ohio winters, my '04 shows the wear and tear of 18+ years in Ohio.
I was gonna comment on the Charger in the pic above earlier, and forgot. Love the color! I'd have that in my garage any time.
Discussion Starter · #13 ·
Body is straight, never crashed, California car with no rust, drilled and slotted rotors with ceramic brakes, paints good, minimal dings and interior is way above average for the age…. She’s a keeper 😂🥃.
so is the Charger😜
I would put that kind of money into my Roadrunner because it will create value in it. I understand that your DD is beautiful and well-cared for but at 300K it's honestly just going to keep costing you money. Sometimes you have to make a business decision, not an emotional decision. By the way, you didn't say what happened when "BOOM."
Discussion Starter · #15 ·
Discussion Starter · #16 ·
Well, based on how it happened and not getting into tearing it down (only having it towed home) or doing any detail inspections on it, I’m quite sure I had a bad internal failure. May have been a valve let loose, may have punched through a piston… won’t know for sure for a bit. What I do know is that it made a bad noise, sounded and shook like a blown tire… got to the side of the road instantly as it shut itself down and a bunch of oil smoke came out the top end… oil all over the bottom end which means to me that it may have cracked the block at the same time but, one things for sure… since I got the average max life out of it, I’m not going to mess with it. It served its time and I’m happy with the miles it gave us 😎
2018 Durango R/T AWD
Don't listen to Tinfoil hat. He just goes around ripping everyone else while his cars sit on blocks
Such rubbish! Go back to the can Oscar!
I'm 48, and that kind of payment will NEVER be my thing. :)
Cars are like women. ALWAYS, "cheaper to keep her" .
1 - 20 of 20 Posts
