Silver Ghost said:
The truly critical pieces to the tow package are: Class III/IV hitch; wiring to accept brake controller (though you could do that yourself), and the tranny cooler (though many folks are getting additional cooling).
Couldn't all of those items above be added later fairly easily? With a boat, no need for a brake controller since most, if not all, will be surge brakes. The hitch is a given, the tranny cooler can be put on for $50 to $100. I'd add a tranny gauge for ~$150. The biggest factor IMO in this case (besides what SG lists above) will be the 3.55 gears. If it's new tire time, you could go with a lower profile tire and get the equivalent of a better gear ratio.
Just a side note for WD hitches and a boat. Most surge brakes don't work together with WD hitches. Double check that your coupler/actuator and WD gear are compatible.
Another tip is to look on the rear diff pumpkin for a tag on one of the bolts that'll tell you the gear ratio -- unless someone hasn't left it off during servicing.
Gregb, what size boat and trailer? Single or dual axle? If you have the boat specs that can help too.
Here's some good boat trailering reading:
http://www.trailerboats.com/output.cfm?id=1199251
This link below shows you're OK to 4400 lbs. You go to 5700 just by getting 3.92 gears. This is assuming 4WD vs 2WD. The database doesn't say anything about trailer tow package. I really don't know if a tranny cooler or radiator is the same size with or without the package. The alternator or surge brake doesn't matter with a small boat IMO
http://www.trailerboats.com/towrati...ndex.cfm?action=search&yr=2003&make=Dodge&model=Durango&min_tlimit=&max_tlimit=
Small boat trailers weigh ~1000 lbs, then the dry boat, then gas, then toys, then people, finally, food and drink. It also depends on where you'll be towing, how far, and what type of terrain.
