1 - 10 of 10 Posts
Discussion Starter · #2 · (Edited)
2003 Durango Front diff torque specs.
I posted this mainly because of torque specs for the front diff cover bolt's.
Gear oil.
75w-90 for little to no towing.
75w-140 for towing.
Don't forget limited slip additive if you are using gear oil that doesn't have it included.
Discussion Starter · #6 ·
2003 Durango propeller shaft.
I've seen numerous YouTube videos on how to replace, and in every video no one mentions marking the shaft or if they do it's marked wrong.
Discussion Starter · #9 ·
Tailgate support (called lift cylinder, lift shock, life support, etc.)
I hear people say hand tighten, but there's torque specs for the bolt's
250 in-lbs convert to ft-lbs 20.83333
Torx size is 40
Discussion Starter · #10 ·
I purchased a 2003 Durango SXT and I'm rebuilding it myself.
I'm so f..ing tired of searching Google or asking for torque specs. Most of the time they are wrong specs. As Don said to me in 2020 buy FSM and I finally did (took long enough haha). I'm sharing the correct torque specs. I hope this helps anyone (just buy me a damn coffee in return haha)
1 - 10 of 10 Posts
