1 - 5 of 5 Posts
I have a 2003 Durango SLT 4.7L. I have had it since 2004, with 11k miles. I am now at 190K. I have done routine maintenance through the years. So I know everything that has been done, do aviation electrical work by trade, have little knowledge mechanically to be dangerous.
Recently I have had several issues. I have bounced ideas off aviation engine mechanics at my work and possible avenues.
First issue, when I come to a stop, I idle around 500-530 RPM. But When I go to neutral, park, or reverse, it corrects itself up to 650-700. That low idle almost feels as it will stall.
Second issue, it seems temp related. In the mornings I drive to work, the acceleration is great. But when driving home in after noon, it feels like the air/fuel mixture seems off. As if I’m losing a cylinder or power. The RPM will rise, but the MPH lags behind. My shifting is smooth still.
Note: When I am at the light stopped, with foot on brake, I can press on the gas, while braking, and when I left off the gas, it stays at the correct idle and doesnt drop back down to 500-530.
There are no CEL for any of these issues.
I have replaced the TPS x 2, IAC, MAF sensors. I’ve thoroughly cleaned the throttle body and IAC valve. Less than 6 months ago I replaced the Fuel Pump assembly due to failure after 15 years. This past weekend I replaced all plugs, and checked the ignition coils (which all read the same).
At this point I wanted to run by other members here. I just received a scan tool, and running DashCommand(Full Version). There are some parameters I am curious about. But I will give a snippet of when I am at low idle. The second issue, didn’t occur this morning so this data may not help that problem.
Note, I noticed yesterday it was 90 degrees ambient, and intake temp was showing 146 F and I had the acceleration issues.
Coolant Temp = 205F Voltage = 14V
Intake TEMP = 90 IGN Timing #1 = 14.0
Ambient TEMP = 78
MAP = 10.9 inHG
VAC = -19 inHG
Boost = -9.3 inHG
RPM = 516
ABS TPS = 12.5%
OXY 02S11 = .195 V
OXY 02S12 = .625 V
Short Term Fuel Bank 1 = -1.6
Discussion Starter · #3 ·
Thanks for reply Chase. I was curious about that. I guess I will need to pull the numbers after work when I drive home to diagnose the 2nd problem. I just couldn't remember it idling that low.
Discussion Starter · #4 ·
Just to have closure. I changed all ignition coils(original and sitting around 195K miles) and the camshaft sensor. My D is performing as it should again. Alot of headache chasing this problem.
Well that's good news.
So think it was the camshaft sensor?
I'm still running the stock coils in my '01 4.7L at a tad over 355,000 so they seem to be quite robust.
Just ran her this morning on an errand and she still purrs.
1 - 5 of 5 Posts
