2001 Durango SLT 4.7 Performance Issues - Codes: P0601 P0204 P0205
7.8K views 37 replies 7 participants last post by  sweersalex
Hello,
I'm helping my dad with his 2001 Dodge Durango SLT 4.7 V8 4x4. It has a little under 180,000 miles. He had it since new, overall it has been an excellent, dependable vehicle.
For the past few weeks it will idle rough and shake a little when stopped at intersections, and when idling. It seems to happen no matter what gear it is in, and in neutral. It has poor acceleration, and it also gets about 12 MPG since the performance issues have been observed, which is significantly worse than it usually gets. (Around 18+ combined is what it got before, when new it was 20+)
It idles at about 620-650RPM (not sure if this is normal). We just changed out the original copper plugs and coils, thinking it would help, and it has not. (But it needed to be done anyway)
I pulled the following codes: P0601 (Internal Control Module - Memory Check Sum Error), P0204 (Injector Circuit/Open Cylinder 4), and P0205 (Injector Circuit/Open Cylinder 5).
We reset the computer by disconnecting the negative battery terminal and turning the key over for 15-30 seconds, and all of the codes went away after reconnecting the battery and starting the vehicle. We took a short test drive and the Durango performed really well, with no codes appearing until we shut it down, and when we started it again, the 3 codes all came back, and the poor performance returned.
A little background, we replaced both the computer and crank shaft position sensor over 5 years ago to resolve a no start, "no bus" issue. (The crank shaft position sensor was the culprit) and it ran fine afterwards with no codes until recently. Not sure if this is related or not to the current issues. The computer was a refurbed unit.
Do you think we need to replace the computer again? I see on eBay you can get them for $150, and need to send the seller the VIN number. I also welcome any advice on how to check the cylinder 4 and 5 injectors/wiring, or if it could be something else. I've read to try replacing the TPS and IAC, both look like easy jobs and the parts are not too expensive, but I don't see how the codes point to these sensors being an issue. Regardless, should these be replaced due to mileage and age?
We also re-seated the three computer connectors, and checked the engine air filter. The battery is about 6 years old, but starts up just fine. I've also read batteries can cause strange issues, but would hate to throw a new battery at it prematurely.
Any insight would be appreciated!
Thank you very much, I know this was a long first post.
Alex
#30 ·
We're hoping we don't need to replace the entire wiring harness that goes to that bundle of wires into that connector to the PCM from the power steering switch that failed. I ordered the power steering switch, the plan is to replace the switch, and use an automotive electronics cleaner spray on the connector that goes to that power steering switch, and also the connector that goes to the PCM. I'm thinking it be best if we remove the PCM, and open it up if we can safely to also spray electronics cleaner in there too, and also to remove any power steering fluid, should any of it pooled inside of the PCM housing.
What a mess! I suppose worse case, is we need to replace the PCM and wiring harness. This explains why we got so many inconsistent results with resetting connectors and the battery, etc.
#32 · (Edited)
Finally was able to work on the Durango again today. We disconnected the battery, and replaced the bad power steering pressure sensor. I also disconnected the power steering fluid soaked PCM connector and of course the connector that went to the replaced power steering pressure sensor and used electronic contact cleaner on them both before connecting everything back together and started it up and test drove it, the P0601 computer code came back quickly but the performance during the test drive was great. We shut the vehicle down, and I repeated the cleaning of the same connectors with the battery disconnected and on the next startup and test drive, the P0601 code went away and the P0204 injector circuit open cylinder 4 code came back and is currently the only code and the poor performance returned on the test drive. I repeated cleaning the wire harnesses with contact cleaner and the P0204 code remains.
So in short, we replaced the bad power steering pressure sensor which I believe was the culprit that started this madness and the P0601 code has gone and P0204 code returned and currently remains. My dad is going to drive it for a week and we plan on cleaning the harnesses again that were affected next weekend if our schedule allows.
I welcome any ideas/feedback!
#33 · (Edited)
Talked to my dad today, he's been driving the Durango for about a week since we last worked on it. He says it will be good about 70% of the time now. Some trips it runs as it should, but some of the time it still runs rough with poor MPG. He still has the CEL, which I presume is still the P0204.
Tomorrow when I'm at my parent's house I plan on unplugging the PCM and power steering pressure sensor and hitting them with the electronics cleaning spray again.
Anything else I should do or check? If the P0204 comes back, I'm tempted to swap the injector from that cylinder with another one to see if the code follows that injector. Not sure how hard of a job that is.
#34 ·
Hi Alex:
Congrats on all of the progress. Moving that injector around to see if the code follows is a good plan IMO.
If so, I'd throw in a new one and see if that cures it.
#35 ·
Hi Don, thank you!
We made further progress today on my dad's Durango. I removed the PCM connector that was soaked in PS fluid before, and it was dry this time but I hit it with electronics cleaner again, and I also pulled the wire harness connector from the injector for cylinder number 4 and hit it and the injector's contacts with the electronic cleaner spray. I did the same with the power steering pressure switch connector where the issue originated before replacing that sensor. Got everything put together again, and on first engine start and test drive there were no codes and it performed well! When we shut it down and started her back up, it ran fine but one code came back, and that was P0601. So as of now, the P0204 is gone. As long as the performance stays good, we are letting the P0601 code remain, as it has had for years with no poor performance. My dad is going to run it again all week and I'm going to check codes again next weekend to see if any go away/return.
#36 ·
An update, my dad has been driving the Durango for another week, and he said it only performed poorly once in several days. I re-scanned the vehicle and got two codes, the P0601, and the P0204 returned. Since it's working most of the time, we're leaving it for now. We talked about possibly trying another PCM from a junk yard from a like model.
#37 ·
Alex:
If you go PCM shopping, be sure that the donor D matches yours regarding the alarm system. If yours has it, the donor PCM needs to have it also. If not, then the donor also should not.
Keep us posted.
Reactions: sweersalex
