06 Durango Manifold exhaust leak
3.9K views 9 replies 4 participants last post by  Joluma09
I started hearing a ticking noise not too long ago so I went to investigate. Seems like the two rear manifold bolts on passenger side are gone. Not sure if there are snapped, rusted off or fell out. Is this a common problem and does anyone have some details on what next steps might be. I don't have a hoist so crawling aroung on the ground. .
Dctaz:
It is indeed common on the 5.7 engines, once they are up in the miles. The 4.7L, to a lesser extent. Dodge used some low bid hardware for these bolts, and it shows. Some searching here should reveal others who have dealt with it.
On the 4.7L I had the exhaust manifold gaskets fail...but none of the studs/bolts for the actual manifold. Some of the ones holding the heat shields have failed however.
5.7L common and typically requires some heat to remove and drilling or welding a nut on to the remaining stud. So a professional recommended..unless you have that skill set.
dctaz:
Plugs on the Gen 2 are not to bad for either V8. The 5.7 has 16 of course. A good selection of extensions, and a good plug socket that will grip the plug helps a lot.
Here is my write up from when I changed the plugs in my '04 5.7L in May of '14 at 50k. Your '06 won't have the plug wires of course.
2004 Hemi plugs changed!
dctaz:
The oem Champion copper plugs are spec'd to be changed at 30k miles intervals. You can stretch that a bit. I a ran a set for 50k, with no noticeable change in performance. I'd not go past that though.
Re the wires, the '04 and maybe the '05 had a secondary wire that runs to a plug on the opposite bank. The wire was discontinued for '06 I believe.
