1 - 11 of 11 Posts
Hi, Can anyone tell me where the Oil Temp Sensor is located on a 06 hemi? I have a repair manual but there is no mention of oil temp sensor. I get error Code P0198 - Engine Oil Temperature Sensor A Circuit High when the car starts cold. The error disappears after the car is warmed up. Any suggestions on troubleshooting this
Thanks, John
JB"
I am not aware of a temp sender, but there is a pressure sender on the passenger front side of the block down from the head. You can access that one better by removing the air filter/airbox. OEM is best.
Thanks, I did install a rebuilt PCM. Is it possible the PCM is confused and looking for something that does not exist?
Took awhile to find it in my 2006 FSM 4 manual set. There is a separate Oil Temp Sensor on the Hemi. Located on the front left side of the engine....see the attachment below.
Here's the troubleshooting pages on P0198. Sorry about the crappy picture quality.
3rd page
I have the 2006 FSM 4 manual set available for sale for $85 shipped if interested. Like new condition!
Sorry couldn't resist that sales plug.
Could be the rebuilt PCM. See the troubleshooting pages I posted above.
What was the issue(s) with your original PCM?
Discussion Starter #9
Thanks. the diagram really helped. I was able to locate the oil temp sensor. The original PCM was causing issues with a deactivation solenoid. The new rebuilt PCM fixed the issue but have been getting this intermittent oil temp code. I am going to check the sensor to see if it is the issue
Good work DuRon! I learned something today. I wonder if my '04 has that sensor too? I have never seen any kind of oil overtemp indication, which I guess is a good thing.
Discussion Starter #11
I tested the resistance of the cold temp sensor and it was about 8 or 9 KOhms. I read somewhere most cold heat sensors are around 2 KOhms. Does anyone know what the cold resistance should be?
1 - 11 of 11 Posts
