About to scrap my '04 Limited with $2000 in parts and a hundred hours in maddening he - Page 2
Page 2 of 2 FirstFirst 1 2
Results 11 to 15 of 15
Like Tree4Likes
Thread: About to scrap my '04 Limited with $2000 in parts and a hundred hours in maddening he
  1. #11
    Grasshopper TowDurango's Avatar
    Oct 2007
    59
    1606
    2 times
    1999 Dodge Durango SLT 5.9L 4WD 2WABS Rear AC
    Headers, Trans cooler, Gauges, Towing
    I'm with Swat455 on grounds. The block will be grounded, but there should also be grounds at the back of the heads. I'm not that familiar your year, but every vehicle I have taken apart had grounds between the back of the heads and firewall.
    Another possibility is an intake leak, since the heads were removed. That should be easy to see on the LTFT with the OBDII scanner.
    99 5.9L Durango 4x4, ~100k mi, thermostatic trans cooling setup, MSaine Performance Transmission
  2. #12
    May 2018
    44
    46337
    12 times
    Check fuel pump or fuel relays .
  3. #13
    Oct 2016
    53
    18633
    5 times
    My money is a ground. My truck would go into limp mode periodically. Became more and more often.If I turned it off and waited it would start and run fine...for awhile. Finally tracked it down to a dirty ground from the throttle position sensor to the block. I had changed the TPS and accelerator pedal assembly. All the grounds were tight. I was sick of fighting and started taking the grounds off and found a bit of rust on one. I wired brushed it and have not had a problem for a year now.
    17 Durango RT Granite Metallic Clear Coat with Blacktop
  5. #14
    JCC
    JCC is offline
    Senior Member
    Jan 2015
    390
    8700
    78 times
    Wait.. Swat I think nailed this. When you say E87 that would mean ethanol 87? Sold at pumps as e87 and not your standard regular 87 Octane fuel? The Hemi is not a flex fuel engine and should not be running E anything. That being said just changing back may not solve the issues running e anything created.
  6. #15
    Oct 2018
    31
    50268
    Just curious what was the final issue was
  1. Replies: 0
    Last Post: 03-21-2018, 10:55 AM
  2. Higher he and to in the ram and charger v6
    By Redeye14 in forum Durango Discussions 2014+
    Last Post: 11-27-2015, 04:49 PM
  3. Took my D to the dealer for recall and other stuff... 12 hours later.
    By Tony H in forum Durango Discussions 2014+
    Last Post: 02-05-2015, 05:14 AM
  4. Pictures of my new Citadel after a few hours of playing
    By Burgh Boy in forum Durango Discussions 2014+
    Last Post: 07-16-2014, 03:25 PM
  5. Should I lend my D to Obama while he's here?
    By Oslo D in forum [General] Dumping Ground
    Last Post: 12-11-2009, 10:01 AM
