2015 Durango R/T AWD Knock over bumps????
Results 1 to 4 of 4
Thread: 2015 Durango R/T AWD Knock over bumps????
    Mar 2019
    40
    52422
    4 times
    This is my first durango but I've owned two new grand cherokees and none of them made this noise over bumps. I know the R/T has stiffer suspension but I'm unsure if this knock is normal or not. It rides perfectly fine any other time but there is an audible noise when I go over bumps. I'm ordering new sway bar end links since they aren't very expensive. Any other ideas? I just don't want to whine about it because I'm not familiar with the way these R/T's handle bumps etc.
    If anyone has any ideas I'd appreciate it. The Durango has 28000k on it
    Durango Jedi Citadel Brian's Avatar
    Jan 2014
    New Jersey
    2,035
    3771
    521 times
    If it's coming from the rear, it's most likely the rear upper shock mounts. Pretty common problem with the self leveling shocks.
    2014 White Citadel 5.7 loaded except for DVD
    2007 Jeep Grand Cherokee 5.7 Limited QDII
    1968 Pontiac Firebird 350 4spd #'s matching
    2003 HO Cummins Ram 6spd QCSB sold.
    Mar 2019
    40
    52422
    4 times
    haven't noticed anything in the rear although it does squeak back there when going over a big dip. I was thinking some bushings of some sort. The knock is in the front. I hate buying used stuff, on the otherhand I don't mind fixing stuff either.
    Mar 2019
    40
    52422
    4 times
    got some progress tonight. the l bracket underneath on the drivers side was loose. Thankfully someone on youtube posted their solution to that problem.
  1. 2011 Durango heat rattling sound over bumps
    By ffl3883 in forum Durango Discussions 2011-13
    Last Post: 09-11-2017, 07:29 AM
  2. Wobbling at slow speeds and clunking over bumps
    By Logjammer13 in forum Durango Discussions 1998-03
    Last Post: 09-20-2016, 10:26 PM
  3. Squeeks over bumps and dips
    By GreenDurango2002 in forum Durango Performance 1998-03
    Last Post: 04-25-2016, 03:48 PM
  4. Front end noise going over bumps
    By RocketFoot in forum Durango Discussions 2011-13
    Last Post: 03-02-2016, 03:37 PM
  5. Knock when breaking or turning and going over bumps...sometimes
    By elcid2000 in forum Durango Discussions 2014+
    Last Post: 02-15-2014, 09:51 AM
