Occasionally dies at stops
Results 1 to 7 of 7
Like Tree1Likes
  • 1 Post By Durangutan
Thread: Occasionally dies at stops
    Grasshopper Greggo63's Avatar
    May 2018
    6
    46465
    I’ve got a 2003 DD SVT 5.9 2wd.
    Occasionally when it comes to a stop it dies. The check engine light is not coming on.
    All I’ve done so far is clean the throttle body, tps and iac valve and it is still having the problem.
    Any input is greatly appreciated!
    Jul 2007
    Real close to Muffler Man
    4,947
    1532
    848 times
    2007 Durango Night Runner
    1 of 241 made
    I would start with the battery. How old is it, and has it been load tested? Weak batteries can account for many oddities, including that. I had that happen myself actually.
    NumberThree likes this.
    2007 HEMI Nightrunner D
    1996 Ford E-350 SuperBeast
    Durango Expert
    Sep 2004
    679
    72
    115 times
    x2 on the battery.
    The electronics in these Dodge vehicles do strange things if the battery is not 100%
    2015 SXT Plus, Billet silver
    Super Moderator tomk's Avatar
    Jun 2004
    Amherst, MA
    12,399
    16
    1568 times
    +1 battery.. check the date code, if it is more than 4 years old just replace it.. don't even bother testing it..
    07 JGC Red Rock Limited 5.7L
    And some past Durangos
    de W1PF
    May 2018
    6
    46465
    Even though it starts right back up, no problem?
  7. #6
    Durango Expert NumberThree's Avatar
    Mar 2017
    SW Florida
    886
    25201
    59 times
    2017 Durango SXT / 2012 Honda Pilot
    Window visors, 4 - 32G dashcams for 360 recording. 2M ham rig (calsign N4ZAW).RF shielded PCM.
    Quote Originally Posted by Greggo63 View Post
    Yes.. X5 on the battery. Have it load-tested at minimum.
    This is a very common cause of the symptoms. I realize how absurd that sounds, but it has a history of driving FCA owners crazy.
    From the land of the midnight sauna
    My Hobby Homepage
  8. #7
    Durango Expert
    Sep 2004
    679
    72
    115 times
    If the battery is even slightly suspect, the PCM can't keep idle, causing the dying you're seeing.
    My 01 and my 03 both had these exact symptoms as the battery started failing.
    New battery, feathered the throttle for about 5 minutes, drove about 10 miles and it was perfect again.
    PCM re-learned proper idle and throttle positions.
  1. Starts dies starts dies x3 then STARTS
    By dangokid in forum Durango Discussions
    Last Post: 05-17-2016, 08:56 PM
  2. Durango occasionally dies on idle and will not start!
    By Csaylo88 in forum Durango Discussions 1998-03
    Last Post: 09-11-2014, 08:42 AM
  3. 2001 Dodge Durango 4.7 occasionally going into limp mode
    By Jerramie in forum Durango Discussions 1998-03
    Last Post: 07-25-2014, 08:34 AM
  4. Have power but occasionally won't start.
    By panzer948 in forum Durango Discussions 1998-03
    Last Post: 08-02-2010, 09:57 AM
  5. Tranny won't engage occasionally
    By DavidBarron in forum Durango Discussions 1998-03
    Last Post: 06-14-2010, 10:06 PM
