2011 LED signal bulb swap
Results 1 to 1 of 1
Thread: 2011 LED signal bulb swap
    Apr 2019
    25
    52704
    2 times
    OOPS SORRY WRONG PLACE somehow. Reposted
    Have a question on the signal bulbs. Can I swap out the incandescent signal bulbs to LED and NOT have the hyper flash thing go on. I was in the books today and there is no real "flasher" anymore. I forget what they call it but some kind of module is what controls it. I know they make the old style "plug in" flashers that are specifiacly made when you add LED bulbs. I'm guessing it has a resistor built in. I guess I could buy a handful of bulbs off e-bay and just try it and see.
    On a second note, LED headlights. I have the OEM non HID headlight assembly's, will LED's work and not melt the reflector thing they go in behind? What about HID bulbs? If that little thing is just a plastic reflector, those HID bulbs get plenty hot, so I personally wonder about burning them.
  1. Turn Signal bulb out Error
    By GoChiSox81 in forum [General] Dumping Ground
    Last Post: 04-10-2019, 09:10 PM
  2. Connector to led license plate led bulb
    By timothy001 in forum Durango Discussions 2014+
    Last Post: 10-28-2018, 04:49 PM
  3. Message persists after changing bulb: Front right turn signal burnt out
    By ximportdriver in forum Durango Discussions 2011-13
    Last Post: 09-22-2015, 05:49 PM
  4. Right front signal bulb replacement
    By Sherlock64 in forum Durango Discussions 2014+
    Last Post: 08-10-2015, 07:57 PM
  5. Turn Signal Blinks Right when pushed down for left signal
    By Cagey in forum Durango Discussions 2004-09
    Last Post: 06-12-2015, 06:56 AM
