2016 R/T - Brembo Upgrade
Page 1 of 2 1 2 LastLast
Results 1 to 10 of 15
Like Tree4Likes
Thread: 2016 R/T - Brembo Upgrade
    Apr 2017
    NJ
    70
    27217
    10 times
    2016 Durango R/T
    @GRANITE_RT
    I was able to get most of the information from the thread that was created by DD2015RT. Very helpful thread and gave a good summary of everything. I tried to revive that post but wasn't getting any hits.
    Can someone tell me if the the below list is everything needed in order to do the conversion? Can you also confirm that this would fit a 2016 R/T? All the Durango's that I've seen with the conversion are 2014-2015 unless I'm mistaken.
    Here is the link to the thread where I was able to pull a lot of helpful info:
    https://www.dodgedurango.net/forums/...etup-list.html
    Calipers:
    Caliper - Front (Rght): 68146610AA
    Caliper - Front (Left): 68146611AA
    Caliper - Rear (Right): 68146612AA
    Caliper - Rear (Left): 68146613AA
    Rotors: - https://www.r1concepts.com/geomet
    Front: 380mm - R1 Carbon Geomet Drilled/Slotted
    Rear: 350mm - R1 Carbon Geomet Drilled/Slotted
    Pads:
    Hawk Performance Ceramic Pads
    Hardware:
    Front: NAPA Brakes Disc Brake Hardware Kit, Part #: UP 81596A - https://www.napaonline.com/p/UBP81596A
    Rear: NAPA Brakes Disc Brake Hardware Kit, Part #: UP 83796A - https://www.napaonline.com/en/p/UBP83796A_0311753716
    1BADR/T likes this.
    Junior Member SteveMLS's Avatar
    Apr 2016
    East Earl, PA
    233
    12510
    76 times
    2014 Dodge Durango R/T aka "Altered Carbon"
    Yokohama Parada Spec-X 295/45r20's on 20 x 10, WeatherTech inside & out, Tazer, Jay Greene Tune
    That is the correct numbers for the 2016 as well. The hardware kits aren't needed if you are buying reconditioned calipers, but the crossover lines didn't come with my calipers from Rock Auto, I had to make them myself.
    amelnik likes this.
    Engine Mods:
    aFe CAI, Moe's 87mm TB, Edelbrock Victor II intake manifold, Kooks LT headers w/race cats, Borla S catback, A2Speed valve covers, Granatelli coil packs, Billet Technology catchcan & water neck, 180 deg TS, Mopar oil cooler
    Suspension Upgrades:
    BlackOps adjustable front upper a-arms, adjustable rear control arms, endlinks, strut brace & Road Magnet lowering springs
    Chrome Brakes® rotors, Brembo calipers, Hawk ceramic pads, 3.70 front & rear diffs
    Apr 2017
    NJ
    70
    27217
    10 times
    2016 Durango R/T
    @GRANITE_RT
    Quote Originally Posted by SteveMLS View Post
    My plan was to buy new calipers so I'm assuming that I'll need the kit then. My apologies if this is a stupid question but what do you mean by crossover lines? I'm clueless when it comes to this. Can you reuse the stock brake lines or do I need to upgrade those as well?
    Apr 2016
    East Earl, PA
    233
    12510
    76 times
    I believe new calipers also come with the hardware as well, just check with the supplier. Your stock calipers have pistons on the same side as the brake line. Brembos have pistons on both sides of the rotors, so a crossover line has to supply the fluid to the outside pistons. I would also suggest replacing the stock brake lines with SS upgrade.
    2016 R/T -  Brembo Upgrade-brembo.jpg
    Engine Mods:
    Apr 2017
    NJ
    70
    27217
    10 times
    2016 Durango R/T
    @GRANITE_RT
    Click image for larger version.
    Thanks. Do you have any recommendations for SS brake lines?
  7. #6
    Apr 2016
    East Earl, PA
    233
    12510
    76 times
    Goodridge 15010 G-Stop Ss Braided Brake Line Kit .
    Engine Mods:
  8. #7
    Apr 2017
    NJ
    70
    27217
    10 times
    2016 Durango R/T
    @GRANITE_RT
    Apologies for the hundred questions but just looking to make sure I have everything. Would this include the crossover lines as well?
  9. #8
    Apr 2016
    East Earl, PA
    233
    12510
    76 times
    No they do not. You said you were buying new, not reconditioned calipers, the crossover lines are hard piped and come with the new calipers.
    Engine Mods:
  10. #9
    Apr 2017
    NJ
    70
    27217
    10 times
    2016 Durango R/T
    @GRANITE_RT
    Perfect. Thank you, I appreciate it!!
  11. #10
    Senior Member DuRonbo's Avatar
    Nov 2017
    Tiny Pebble, AR
    446
    37945
    137 times
    2008 Limited
    Ongoing
    Had Brembo brakes on my 2006 Magnum SRT-8. Gnarly brakes!
    ereds83 likes this.
    2008 Durango Limited with every option available
    2004 Durango SLT (For Sale soon)
    2002 Chrysler 300m Special
    2000 Dodge Intrepid R/T
  1. Brembo brake upgrade question (I know right)
    By JACO in forum Durango Discussions 2014+
    Last Post: 09-14-2018, 01:35 PM
  2. SRT Brembo upgrade question
    By amelnik in forum Durango Discussions 2014+
    Last Post: 11-14-2017, 02:57 PM
  3. Upgrading to WK2 SRT8 Jeep Grand Cherokee Brembo's
    By unixadm in forum Durango Discussions 2014+
    Last Post: 09-12-2015, 06:56 PM
  4. Brembo rotors
    By Durango_Traveler in forum Durango Discussions 1998-03
    Last Post: 05-27-2005, 01:15 PM
  5. Brembo vs Powerslot
    By 01 4.7 R/T Wannabe in forum Durango Discussions 1998-03
    Last Post: 10-16-2004, 08:03 AM
