Cranking too long, smell gas Vol. 2 - Page 4
Page 4 of 4 FirstFirst ... 2 3 4
Results 31 to 38 of 38
Like Tree11Likes
Thread: Cranking too long, smell gas Vol. 2
  1. #31
    Grasshopper RamboStallone's Avatar
    Aug 2017
    23
    34305
    5 times
    You're going to scratch your head at this! For fuel here we have 87, 89, and 93 octane gas. I usually put in mid-grade 89 octane fuel since that is what I believe the manual recommends. Yesterday I decided to put premium 93 octane instead, and the check engine light and starting issue went away!
    I have not done anything, the plugs and wires are still sitting I have not installed them. It's only been a day but both issues seem to have gone away.
  2. #32
    Grasshopper Juicyblunts's Avatar
    Aug 2018
    Alberta, Canada
    29
    49646
    12 times
    2006 Dodge Durango Limited, 5.7 HEMI
    Bilstien 4600 Series Shocks, LED lights
    Quote Originally Posted by RamboStallone View Post
    That is quite odd. I don't know much about fuel or fuel injection, maybe it's a difference in quantity or quality of detergents used in premium fuel? Wish I'd have thought to try that, but I'm not sure it would have been a permanent solution. Regardless, good on you for finding a solution that didn't cost a ton of money.
  3. #33
    Aug 2017
    23
    34305
    5 times
    Quote Originally Posted by Juicyblunts View Post
    It came back eventually. Just a coincidence at the time I guess.
  5. #34
    Aug 2018
    Alberta, Canada
    29
    49646
    12 times
    Now that I can relate to lol. Do you have any shops nearby that can check your injectors for a reasonable price?
  6. #35
    Aug 2017
    23
    34305
    5 times
    Yes lol gets your hopes up then it returns to let you know you failed guess again haha.
    I will look into it, its obvious that the true issue is with the fuel injectors. I became side tracked with the idler pulleys, tensioner, and serpentine belt. My lower idler pulley was nonexistent, all that was left is the metal rings...
  7. #36
    Oct 2014
    Tampa, FL
    2
    7719
    2014 Durango rallye
    My 14' durango has been experiencing the same starting problem for a year but without the gas smell. Over the past year it has gotten progressively worse. It only has the issue when sitting for between 1-6 hrs. Cranking first thing in the morning is no issue nor is it an issue turning vehicle off then immediately back on. Dealer just replaced the TIPM to no avail. I'll request the injectors be inspected and see how that works out.
  8. #37
    Aug 2018
    Alberta, Canada
    29
    49646
    12 times
    Quote Originally Posted by 3rdtimer View Post
    Hope you get it figured out! It was an annoying issue. If you have your injectors looked at and they tell you they're fine, get a second opinion to be safe. Unless you know/trust them. I will forever boycott the shop I took mine to initially. Either way, best of luck to you!
  9. #38
    Junior Member
    Jan 2014
    241
    3699
    31 times
    Any luck on a resolution?
  1. 2003 Durango- starter or ignition problem when cranking?
    By njpiney in forum Durango Discussions 1998-03
    Last Post: 11-14-2016, 02:55 PM
  2. Excessive Cranking and car stalls immediately
    By Monolith in forum Durango Discussions 2004-09
    Last Post: 02-08-2016, 05:01 PM
  3. Replies: 6
    Last Post: 04-24-2015, 09:08 AM
  4. Cranking torsion bars
    By BigRick01R/T in forum Durango Discussions 1998-03
    Last Post: 03-22-2006, 03:55 AM
  5. Problems Cranking Torsion Bars
    By earlmred in forum Durango Accessories 1998-03
    Last Post: 02-26-2006, 06:37 PM
