2016 Tailgate (center) and license plate lights no longer working. Fuse?
Results 1 to 3 of 3
Like Tree1Likes
  • 1 Post By NumberThree
Thread: 2016 Tailgate (center) and license plate lights no longer working. Fuse?
    Mar 2019
    6
    52498
    Unhappy 2016 Tailgate (center) and license plate lights no longer working. Fuse?
    Just noticed this morning that the racetrack center LED light assembly no longer lights up. Is there a fuse I should check before taking it all apart? No evidence of water though.
    I did a search, but nothing comes up. YouTube neither. Please help.
    Durango Expert NumberThree's Avatar
    Mar 2017
    SW Florida
    879
    25201
    54 times
    2017 Durango SXT / 2012 Honda Pilot
    Window visors, 4 - 32G dashcams for 360 recording. 2M ham rig (calsign N4ZAW).RF shielded PCM.
    Unknown, but on my 2017, there is no fuse back there. I know that because I had all of it ripped limb-to-gut, installing a rear dashcam in the liftgate... It came out great, BTW.
    There WAS however, a connector that is common to both tag lights and the racetrack behind the trim panel, so the trim will need to be removed to inspect it. There isn't much guesswork to it, as I recall, but getting to it was somewhat of a chore. Unless you're willing to remove the rear liftgate trim to get at it, I would make an appointment with the dealership.
    But if you are willing to save some cash, while assuming a very minor risk of damaging a clip or two in the process, just view some of the tutorials on youtube and have at it..
    You'll likely find that connector loose, or corroded The following video may give you an idea of the procedure of getting TO this connector;
    Stellasdad likes this.
    From the land of the midnight sauna
    My Hobby Homepage
    Mar 2019
    6
    52498
    Thanks, NumberThree
  1. O/D no longer working '02 5.9 RT
    By Kent in forum Durango Discussions 1998-03
    Last Post: 01-24-2019, 12:11 PM
  2. Replies: 14
    Last Post: 05-10-2018, 11:07 AM
  3. Adding front license plate
    By Waykul in forum Durango Discussions 1998-03
    Last Post: 03-03-2005, 08:28 PM
  4. Front license plate holes. Help!
    By BIG D in forum Durango Discussions 1998-03
    Last Post: 01-04-2005, 10:26 AM
  5. License Plate Bracket
    By Hooked4Life in forum Durango Discussions 1998-03
    Last Post: 10-11-2004, 11:36 AM
