Dodge Durango Aftermarket Exhaust Tips - Page 2
Page 2 of 5 FirstFirst 1 2 3 4 ... LastLast
Results 11 to 20 of 41
Like Tree7Likes
Thread: Dodge Durango Aftermarket Exhaust Tips
  1. #11
    Mar 2019
    NJ
    34
    52228
    5 times
    Dodge Durango R/T
    Quote Originally Posted by ORT View Post
    This is what I have, fit the cutout in the bumper perfectly. I took the bolt out and just welded them on. Easy install and look great.
    https://www.amazon.com/gp/aw/d/B00YC...H9YKDVCF&psc=1
    Just an update.
    I actually ordered some black tips already, but will have these as my backup in case those don’t look right. Thanks
  2. #12
    Junior Member PhilB's Avatar
    Jul 2018
    119
    48888
    16 times
    Quote Originally Posted by R/T19 View Post
    Actually look awesome. Quick question though because I have found a few with those specs. The inlet on these is 2.5 and OEM is 2.25. Did you have to add an adapter? Also do you have a side photo? Thanks
    I can get you a side photo maybe tomorrow, currently in the middle of a snow storm here.
    No adapter. What I did is I cut the old tips off flush at the tip leaving an inch or two of pipe coming out of the resonator. Then got a piece of 2.25"id pipe of that same length and put it over that stock piece then put the tip on. That extra sleeve of pipe made it the exact size of the inlet of the tip. Then just welded it all together.
    Would it have been possible for you to bolt on the new tips. I'm not into welding and need an easy fix.
  3. #13
    Mar 2019
    NJ
    34
    52228
    5 times
    Dodge Durango R/T
    You can bolt them on. They are meant to be bolted. You would just have the shop cut off the stock tips and leave an inch or so of piping coming out of the muffler. The new tips will go ontop and would be tightened using the bolts. You will need an adapter since those tips are 2.5ID and the stock piping is 2.25, but yes you can bolt them. It’s just better to have them weld or maybe hit them with some tacks to keep them in place.
  5. #14
    Junior Member
    Sep 2016
    143
    16762
    16 times
    Hey you got any more pics of the Pypes tips installed? I’ve had those Redtail 4” tips for almost a year and haven’t had them installed yet. I’m thinking 4.5” is the way to go instead.
    Sent from my iPad using Tapatalk
  6. #15
    Jul 2018
    119
    48888
    16 times
    Hello Everyone,
    New to the forum. Recently leased a 2019 Durango RT and was looking to upgrade the exhaust tips. It’s Knuckle White with Black Interior and the Blacktop package, so I was looking to add some black exhaust tips to match the wheels. Was thinking of the Jeep SRT ones, but they will cost over $300 +installation and they would need a reducer, as their inlet size is not 2.25. I’ve measured the stock exhaust tips and they are 4 inches long and 3.5 wide. Was looking for something with an inlet of 2.25 to match the stock, outlet of 4-4.5 and length of 6-7 inches (Double Wall/Slant Cut) to make it look more aggressive, but it has been extremely difficult to find. I have found a Magnaflow that has specs of 2.25 x 4 x 7 but it’s not double wall and it’s SS, so I would have to paint it.
    Has anyone found any glossy black tips that did not need some sort of modification? Prefer them to be flush with the cutout, and by my measurements, that’s a max of 7 inches long.
    Closest I’ve found Is this: DT-24175BK
    Black Powder Coated 4" Resonated Angle Cut Bell Tip
    http://www.dtexhaust.com/images/thum...plmth8rkp69f60
    Kinda look like the SRTs but preferred more of a straight line instead of a bell like look. But then again, that may not show.
    Thanks for your help!
    I was just curious. Why do you want them 6 to 7 inches long when the stock tips were only 4 inches?
    Wouldn't they be sticking out too much?
  7. #16
    Mar 2019
    NJ
    34
    52228
    5 times
    Dodge Durango R/T
    The original tips sit too far back, which is the main reason I wanted to change them. If you measure from the muffler to the bumper (flush), you get 7-7.5 inches. If you find a 2.25 inlet exhaust tip that is 7 inches long, you will sit perfectly flush with the cutout of the bumper.
    I found 2.5 inlet ones 4 inch wide and 6 long (APR brand), added an adapter and for brought them flush with the bumper. They don’t stick out at all.
    Attached Thumbnails Attached Thumbnails Dodge Durango Aftermarket Exhaust Tips-0e5923e7-bf82-48e0-bc98-432dbfb6932d_1556394881889.jpeg   Dodge Durango Aftermarket Exhaust Tips-09dc439e-1fe7-46b7-80fe-c03b70682599_1556394901371.jpeg   Dodge Durango Aftermarket Exhaust Tips-aef77ea3-5c06-45f1-b701-059f2d0429f7_1556394925243.jpeg
    LIDurangoRT likes this.
  8. #17
    Jul 2018
    119
    48888
    16 times
    So I take it you couldn't find 4 1/2 inch?
    And one other question, did you clamp them on or did you have to weld them?
    R/T19 likes this.
  9. #18
    Mar 2019
    NJ
    34
    52228
    5 times
    Dodge Durango R/T
    The best 4.5 inch ones are Pypes, which were posted earlier in the forum. I painted the adapters and clamps, and had them clamped on and through some tacks on there as well so they are more secure.
    The 4.5 would fit the cutout perfectly, so I would just go with the Pypes brand ones which are like $80 for both. The cool thing about the APR ones is that they are black chrome.
  10. #19
    Jul 2018
    119
    48888
    16 times
    Thanks for the info.
    I just placed my order for the Pypes on Amazon.
    R/T19 likes this.
  11. #20
    Grasshopper LIDurangoRT's Avatar
    Jul 2018
    53
    49358
    19 times
    APR brand in chrome 4" flush to bumper.
    R/T19 likes this.
    2016 Dodge Durango RT - Modded
    1993.5 Supra TT HT BPU++++ 6MT 40K orig miles
    2006 ZO6 6MT 703HP 20K miles
  1. Replies: 2
    Last Post: 02-24-2014, 09:11 PM
  2. Building an exhaust tips? any "tips"?
    By sw1tch_nut in forum Durango Accessories 1998-03
    Last Post: 08-17-2010, 09:42 AM
  3. new dual exhaust tips
    By paisley_tele in forum Durango Photos/Videos 1998-03
    Last Post: 04-03-2008, 11:12 PM
  4. How do tips affect exhaust sound?
    By Jackseric in forum [General] Dumping Ground
    Last Post: 04-20-2005, 02:02 PM
