2017 R/T loooooooong crank
Results 1 to 3 of 3
Thread: 2017 R/T loooooooong crank
    Jul 2018
    3
    49108
    1 times
    Just had it in to the dealer (twice) for MIL. They replaced the fuel vent module near the fuel tank fill/gas cap (capless) area. Now more than several times a day it cranks really long before it starts; intermittently. It seems random and doesn’t do it every time, but it does seem to be getting more frequent. Any ideas what it could be before I take it back? Thx!
    Senior Member
    Jan 2014
    250
    3699
    31 times
    Sounds similar to my 2018RT which was replaced under the lemon law. Dealer had no clue.
    Good luck. I hope your dealer is better than mine. They replaced both fuel pumps and it did nothing.
    I have read other members with this issue....check the injectors. They might be leaking down after you turn the vehicle off. Does it happen a set time after your shut it off? Mine did it when it was off for 60-90 minutes.
    Does it have smoke or smell from the exhaust?
    Jul 2018
    3
    49108
    1 times
    No smoke, no smell. Seems to do it after it sits longer. Dealer has been spectacular with all our vehicles so far.
  1. Crank/Harmonic Balancer Bolt Removal
    By Dadditruck in forum Durango Discussions 1998-03
    Last Post: 07-08-2011, 05:10 PM
  2. Crank sensor, where is it?? Or where's my manual??!!
    By Wile E Coyote in forum Durango Discussions 1998-03
    Last Post: 02-03-2009, 08:25 PM
  3. Re-align after TB crank
    By mtbiker in forum Durango Accessories 1998-03
    Last Post: 04-30-2007, 11:33 PM
  4. 2000 5.9 long crank time
    By gopherfan in forum Durango Discussions 1998-03
    Last Post: 05-31-2006, 08:09 AM
  5. Crank time has gotten longer?
    By shadango in forum Durango Discussions 2004-09
    Last Post: 06-06-2005, 10:24 AM
