5th to 4th, Hard Downshift - Page 11
Page 11 of 11 FirstFirst ... 9 10 11
Results 101 to 109 of 109
Like Tree12Likes
Thread: 5th to 4th, Hard Downshift
  1. #101
    Durango Expert jfire72's Avatar
    May 2014
    Michigan
    688
    5459
    162 times
    2018 R/T
    Just out of curiosity, when it's downshifting, is it doing it kinda quick? Like on mine when coming to a stop, it is still in 4th gear at around 10 miles an hour or less. Now in Sport Mode it will downshift quick than that. I don't remember what gear I'm in at that speed, but it is lower than 4th.
    I don't have the rough shifting issue on my R/T is why I ask this. My 5th to 4th is fine as well. Just wondered if maybe the transmission was downshifting faster than it is suppose to, possibly causing the rough downshifts. If that is the case, it would seem like the computer is telling the transmission to downshift too early. One would think the to PCM or what have you needs reprogrammed/replaced, maybe there is a bad batch of them? Especially after several of you have reported it came back after getting parts replaced.
    2018 R/T
    Muffler Delete, Tail Light Vinyl, Dodge Tail Light Letters Removed, Black Exhaust Tips, Chrome Tailgate Letters Replaced W/ Blacktop Badges, Chrome R/T Front Grill Badge, Thinkware F800 Pro Front & Rear Dash Cam
  2. #102
    Oct 2015
    Minnesota, USA
    25
    11094
    1 times
    2015 Dodge Durango RT Brilliant White
    AFE CAI, Corsa Catback exhaust
    It's not really a matter of how quick/slow or when it downshifts as long as it's smooth. When I had the problem of 5>4 downshift, myself and others in the car, thought we got rear ended. It's that clunk/jolt when downshifting. Kinda like a bad shift when driving a manual where don't blip the throttle and release the clutch to quick.
    Given that, programming could still be a root cause but after X miles of bad shifting due to programming issues, is there physical part damage as a result.
  3. #103
    May 2014
    Michigan
    688
    5459
    162 times
    2018 R/T
    Quote Originally Posted by RedHeckle View Post
    Gotcha, thanks for the clarification!
    2018 R/T
  5. #104
    Dec 2014
    Massachusetts
    39
    8309
    6 times
    2015 Durango Citadel Hemi
    LED Fogs, front tints
    I have a 2015 Citadel with the Hemi and about 40,500 miles now but around 38, 000 at the time.
    I also had the very rough 5 to 4 downshift and occasional 2 to 1 rough downshift for the 3 years ive owned it. It seemed more pronounced with AC on initially but then was just rough all the time and like others have said it felt like i was rear ended and checked behind me a few times to see.
    After reading here that not much can be done to fix it I never mentioned it to my dealer until I had a bigger problem with it. On 2 occasions the transmission clunked into 4th louder than usual and then resulted in a check engine light code P0734 and the vehicle in limp mode staying in 4th gear until i turned it off and restarted. First time I brought to dealer the light went off the morning i was bringing it in and they refused to do anything without an active code. Then after the 2nd time (about 3 months later) this happened i brought it right to dealer so the code was still active. At first they tried to just say it went out and is shifting normally now but I pushed them to look further to the cause of the limp mode and CEL. about an hour later they called and said they were going to replace the transmission and waiting on final approval from FCA. Then about a half hour after that they called back and said it was approved and on order. seemingly a total 180 as they were not going to do anything initially. I know it doesnt sound like it, but i really do like my dealer and service people. they have been very good overall, although sometimes quick to dismiss things at first but usually come through for me. Much better than any of the other dealers in my area have been.
    about 3 weeks later i had the transmission replaced and since then Ive driven about 2500 miles and so far its been great. hopefully it stays this way.
    on a side note: another issue i always had was on the first start of the day, the first 1 to 2 upshift was always delayed and kind of rough but that too has been rectified.
  6. #105
    Junior Member mnunes's Avatar
    Jun 2015
    Fountain Valley, CA
    100
    9945
    33 times
    2015 Durango R/T
    Quote Originally Posted by rasull12 View Post
    I've had this happen, too. Not always, but often enough.
    Good to know that it seems the problem *can* be resolved.
    Maybe it's going to take a second transmission replacement on mine.
    --- Mike
    2006 Charger R/T w/ R&T - Sept 2005-Aug 2015
    2015 Durango R/T - Aug 2015 ----->
  7. #106
    Durango Expert
    Dec 2016
    North Coast
    593
    21433
    152 times
    2014 Limited AWD V6 Premium, Safe/Conveniece & Tow packages, Opt7 LED fog lamps, HD V8 brakes
    I know its worst in my '14 V6 if I leave the Eco mode "on" and its seems less abrupt and/o smoother with the Eco mode "off".
  8. #107
    Jun 2015
    Fountain Valley, CA
    100
    9945
    33 times
    2015 Durango R/T
    Here's my latest update. Had the DD at the dealer for the last week after hearing that TSB 21-013-19 might be a fix. The TSB was issued 3/13/2019 so it's not too old.
    Service order results show this:
    Customer states transmission is not shifting correctly, also shifts very harsh, perform TSB 21-013-19 first and then advise
    TCM not up to date. Need to reprogram module with latest software and test drive.
    Updated TCM module to latest software per TSB 21-013-19 P#68249346AE/AF
    LOP 18-19-05-LH .2 Test drove vehicle. Shifting became worse. Reset adaptives and performed quicklearn. Shifting was still harsh during 5-4 downshift. Performed ETC Learn and found Star Case S1421000017. Performed drive learn adaptation procedure TSB 21-030-14. Drove vehicle 20 miles. Set counters above 2 vehicle shifts are good. No further concerns found.
    I just picked it up last night and only drove about 10 miles so far and it seems fine.k
    Take-aways from this so far, IF it is a true fix:
    1 - the service and tech were able to reproduce my problem. Service writer acknowledged that he's seen this quite a bit
    2 - this is a software problem. Replacing hardware (TCM, PCM, valve body, entire transmission, etc.) might be required if anything got damaged due to extended periods of harsh shifting, but the FIX is software.
    3 - unclear what specifically is in TSB 21-013-19 since I can't find it on the interwebs, but there is a TCM update since 12/26/18 when they indicated no TCM or PCM software available for me.
    4 - there is a Star Case S1421000017 that relates to this issue
    5 - after the TCM is updated, they need to do a drive learn adaptation, which was issued as a TSB back in 2014. This might not be standard procedure after doing a TCM flash.
    I'll continue to give long term updates.
    DuRonbo likes this.
    --- Mike
  9. #108
    Grasshopper Grabber's Avatar
    Jun 2016
    Wheeling, IL
    84
    13233
    15 times
    2016 Dodge Durango R/T AWD
    Stock
    Quote Originally Posted by mnunes View Post
    Following up on this - how has the Durango been driving? Any issues with shifting after a week?
    Been going back and forth with my dealer and I’m hoping to use the info here to help them help me get the DD fixed.
    2016 Billet Silver R/T AWD
    20% Tint - Tinted tail lights - aFe drop-in filter - Philips X-tremeVision LED Fog Lights - WeatherTech Mats -
  10. #109
    Jun 2015
    Fountain Valley, CA
    100
    9945
    33 times
    2015 Durango R/T
    Quote Originally Posted by Grabber View Post
    After 1 week and 300 miles, it's still shifting correctly. This is by far the longest it's been shifting well since they did the cruise control recall/flash last August.
    Grabber likes this.
    --- Mike
  1. 03 Durango acts like it doesn't fully downshift
    By Departure in forum Durango Discussions
    Last Post: 06-10-2015, 07:16 AM
  2. Rough downshift when coming to a stop
    By klasango in forum Durango Discussions 2014+
    Last Post: 11-04-2014, 04:25 PM
  3. Stuck in 5th gear ..
    By tmm403 in forum Durango Discussions 2014+
    Last Post: 04-07-2014, 07:24 PM
  4. Sudden Downshift in my '03
    By prettygentle in forum Durango Discussions 1998-03
    Last Post: 04-19-2007, 07:14 PM
  5. Funk Master Flex Car Show OC Maryland Aug. 5th
    By daveyd in forum Durango Discussions 1998-03
    Last Post: 08-07-2006, 07:38 AM
Search tags for this page
2015 dodge durango rt transmission problems
bump when accelerating from stop
dodge durango hard downshift 5 to 4
durango clunk downshift from 4 to 3
news
