Radar Detector installed! (2014 Durango mirrortap install) - Page 5
Page 5 of 5 FirstFirst ... 3 4 5
Results 41 to 47 of 47
Like Tree9Likes
Thread: Radar Detector installed! (2014 Durango mirrortap install)
  1. #41
    Junior Member MotorMolarDoc's Avatar
    Dec 2014
    Western Washington
    239
    8299
    102 times
    2014 Durango R/T AWD in Granite Crystal Metallic
    [QUOTE=milktruk;197857]Just mounted by Valentine One with Savvy and Blendmount (all inherited from bro-in-law who used in his M3). Had to use a rubber shim since the mirror stem was too thin. The wire goes up and around the windshield, down the left side of my dash, then to the Savvy in the OBD port.
    Still trying to figure out where to mount the remote display.
    Here's where I put mine. Single screw between two main gauges loosens, and allows you to tip them out slighly to thread the wire in behind and connect up with your Saavy or other power source. I built a small wedge "ramp" out of some epoxy putty to angle the display downward some, and glued it to the remote display. Attach it all with double sided foam tape or adhesive of some kind. It does block easy access to the screw, so if you are worried about that you could attach with velcro for easy removal. I love it here, as it is right in my line of sight for the gauges anyway. Not sure why these post sideways, as the image is correct on my computer program. Sorry
    STUART
    Radar Detector installed! (2014 Durango mirrortap install)-photov1-remote.jpg
    Oversteer scares passengers; understeer scares drivers.
    Mod's; Billet Tech catch can and other goodies, Volant CAI, Hypertech Interceptor, Mopar pedals, e-brake and custom dead pedal, Caliper covers, Matte Black vinyl/red pinstripe hood and fender stripes, true Hyperblack rims, debadge.
  2. #42
    Junior Member milktruk's Avatar
    Mar 2014
    Rockland County, NY
    215
    4478
    115 times
    2014 R/T AWD
    [QUOTE=MotorMolarDoc;222384]
    Quote Originally Posted by milktruk View Post
    STUART
    Click image for larger version.
Name:	photoV1 Remote.jpg
    I ended up using some Velcro to attach it to the top of my steering column, just below the center gauge. Its about an inch away from the dash so I can still adjust the steering wheel up/down or in/out without cramming the display into the dash. I drive with my steering wheel low to the point it would block the display if I mounted where you did - but it was an option I explored.
    Pic was taken back in December.
    Mods/Upgrades/Add-Ons: Volant PowerCore, V6 Triton Ambers, 3M 15% Tint, Mopar Bright Pedals (+ Parking), BT Catch Can/Caps/Covers, Husky Liners Mud Guards, Bust a Nut Dead Pedal, Corsa Cat-Back, Fumoto Valve, MGP Caliper Covers, SRT Push Start Button, Micro LED Fogs, Savini Black Di Forza BM-13 20x10 (Mar-Nov), Gorilla Wheel Locks, DiabloSport Trinity (Hemifever 93-Stat), GGR Strut Bar, Thinkware F800/F800R, MotoRad 180 T-Stat, ZAutomotive TaZer, 3D Maxpider Kagu Floor Mats, RCP HIDs
  3. #43
    Durango Guru FINELINETOYS's Avatar
    Mar 2014
    Waterloo iowa
    1,263
    4268
    326 times
    I like it!!! Good job
    milktruk likes this.
  5. #44
    Junior Member
    Apr 2014
    Atlanta, GA
    190
    4758
    48 times
    '15 RT AWD
    I finally migrated from Savvy to RadarMount mirrortap. I've been using V1 for 20+ years but made a shift to Max 360 well over a year ago so functionality of Savvy not necessary with 360, and it appears that Savvy may have been exhibiting a negative side effect, not the battery draw issue, something else that may be corrected with newer firmware, will get my Savvy updated and report back in the future.
    Radar Detector installed! (2014 Durango mirrortap install)-durangomirrortap.jpg
    Quote Originally Posted by 14Hemi View Post
    I may slide the power wire tap back into the connector and attach a ring terminal for the ground and attach that to the ground screw that's right by the connector. I think that the 2 slots being right together may be the reason the fuse blew, since it would be very easy to short them together when installing them - they fit very tight and are right against each other.
    That is exactly why I did just that - the slots on the harness make the power/ground right on top of each other, way too close if not in contact (insulated section). Plus with the second ground line it is extremely difficult to insert the pin into the mirror side harness.
  6. #45
    Grasshopper Adrian97c's Avatar
    Apr 2019
    Port Saint Lucie, FL
    23
    52630
    4 times
    17' Durango RT
    TBD
    Any specific details for a blend mount & MirrorTap install for 2017 R/T?
    Current:
    17' Durango RT
    Previous:
    16' Camaro SS w/ 2SS
  7. #46
    Apr 2019
    23
    52630
    4 times
    17' Durango RT
    TBD
    is the BMX-2000R the correct model# for blendmount for 17' Durango?
  8. #47
    Apr 2019
    23
    52630
    4 times
    17' Durango RT
    TBD
    Quote Originally Posted by Adrian97c View Post
    is the BMX-2000R the correct model# for blendmount/Max360 for 17' Durango?
    Nope!
    BMX 2017 is the perfect fit with the swivel base so radar faces driver set better!
    Blendmount was great with finding a solution after realizing the 2000R had a fixed position & not ideal.
    Radar Detector installed! (2014 Durango mirrortap install)-906ea7e8-e8e0-4ecc-8684-3b8f16758494.jpegRadar Detector installed! (2014 Durango mirrortap install)-d6d7c3ef-4c90-4f34-a27b-1415523505cc.jpegRadar Detector installed! (2014 Durango mirrortap install)-8351ac04-aeee-4ab5-902a-4a00f18d9f66.jpeg
    Current:
    17' Durango RT
    Previous:
  1. 2014 Dodge Durango vs 2014 Ford Explorer
    By cereal killer in forum Durango Discussions
    Last Post: 11-19-2013, 11:12 PM
  2. My new 2014 Durango R/T
    By Lozoya1 in forum Durango Discussions 2014+
    Last Post: 11-13-2013, 07:24 PM
  3. Catch Can Installed on 2014
    By Viper in forum Durango Performance 2011+
    Last Post: 10-24-2013, 09:28 AM
  4. Radar wiring
    By IndyDurango in forum Durango Accessories 1998-03
    Last Post: 09-23-2008, 08:23 AM
  5. Radar Detector
    By Durango_Traveler in forum Durango Discussions 1998-03
    Last Post: 08-23-2005, 09:10 AM
Search tags for this page
2013 dodge durango mirrortap connection
blendmount durango
invisicord durango
mirror tap for radar detector 2013 dodge durango
remove mirror blend dodge durango 2014
