2012 Durango RT 392 Swap - Page 4
Page 4 of 5 FirstFirst ... 2 3 4 5 LastLast
Results 31 to 40 of 47
Like Tree8Likes
Thread: 2012 Durango RT 392 Swap
  1. #31
    Senior Member 1BADR/T's Avatar
    Oct 2016
    VA
    454
    18785
    133 times
    2014 Durango R/T AWD
    Tint, SRT hood
    Keep up the great work, so awesome!
    2014 Durango R/T AWD, Granite Crystal, Tech&Tow Pkg, Nappa, Captains, Sunroof
  2. #32
    Jun 2018
    31
    48618
    9 times
    Okay, so tonight I had time to work on the issues I was having. The MAP sensor wasn't connected, which did need to be extended. The oil pressure sensor also needed extended. So after stripping some wires, soldering, and reinstalling, everything is good.
    One thing to note is, the manifolds I bought have the newer bigger flange size. My Durango has a smaller flange and my factory exhaust won't connect to the manifolds. I ordered some flanges that will fit, and I will have to update my mid-pipes (off-road) to fit the new manifolds.
    Here is another test start. Sorry it's short, it was midnight, had open exhaust manifolds, and no coolant in the engine.
    https://streamable.com/1ic6s
  3. #33
    Jun 2018
    31
    48618
    9 times
    Today I had a chance to do some more work on the Durango. I installed the two front o2 sensors and the tune file I got from HemiFever.
    Unfortunately the first tune file didn't really do much for me. Still won't idle on it's own, and once it drops below 1000 RPM, it sputters and dies, especially if I put it in gear.
    Sean at HemiFever said there was an issue in the DiabloSport dealer software when doing some of the fuel mapping with my PCM file so he's working on resolving that.
    It'll probably be a few more days before I even get a chance to work on it again, but that's all I've got for now.
    The attached image is of the Trinity while the engine is running with my initial tune.
  5. #34
    Jun 2018
    31
    48618
    9 times
    Today I worked on finishing my custom 3" to 2.5" cat-less mid-pipes. Seems to be doing okay. Will try to do some data logging tonight when it cools off outside.
    Video of exhaust, no cats, no muffler, just resonators.
    https://streamable.com/ct4qp
  6. #35
    Jun 2018
    31
    48618
    9 times
    Well, I have some terrible news.
    Yesterday I lost a cylinder, so I pulled the plugs on the dead cylinder and the spark plugs were smashed. Decided to scope the cylinder and there is some foreign debris in it, embedded in the top of the piston. I suspected it might be a piston ring, but it has 150 PSI compression. I've added pics of the scope screen.
    I guess I'll probably be ordering a head, and pistons soon. 😟
  7. #36
    Durango Jedi
    Feb 2014
    Atlanta
    3,875
    3912
    746 times
    Valve seat would be my guess.
  8. #37
    Jun 2018
    31
    48618
    9 times
    It looks like some kind of nail or pin or something straight. Not too sure what it is yet. I'm thinking of popping the head off today to find out. I won't be able to pull the engine back out until next week at the earliest. I really can't imagine what it could be or where it came from, and the scope isn't really that great of quality either.
  9. #38
    Durango Jedi
    Feb 2014
    Atlanta
    3,875
    3912
    746 times
    Yeah, it does look a nail....you think something was in the intake manifold?
    Valve seats are the only thing I can think of that could dislodge from the head and cause that kind of damage....but you'd know it, it'd make a heck of a racket.
  10. #39
    Jun 2018
    31
    48618
    9 times
    It didn't make a sound. It just acted like I lost fire on a cylinder. It's possible whatever it is came from in the intake. It's possible one of the many hands in our shop caused it to happen. No way to know for sure. I've driven it about 65 miles since I put the engine in without any mechanical issues, and now this. It's definitely enough to tick me off, especially since I've had to pull the engine out 3 times already since I started.
  11. #40
    Jun 2018
    31
    48618
    9 times
    Well, it is definitely a broken piston. Possibly from the issues I had tuning it and trying to drive-log it while it was running so rich.
  1. Charger Daytona 392 or Dodge Durango SRT
    By 392DurangoSRT in forum Durango SRT Discussions
    Last Post: 05-07-2018, 02:42 PM
  2. 2012 Durango RT Supercharged
    By 9096 in forum Durango Performance 2011+
    Last Post: 08-17-2015, 06:56 PM
  3. Install SRT 392
    By CMILLE39 in forum Durango Performance 2011+
    Last Post: 08-15-2015, 12:05 AM
  4. 2012 Headlight swap?
    By madd macky in forum Durango Accessories 2011+
    Last Post: 12-24-2014, 10:51 PM
  5. 2012 Headlight swap?
    By madd macky in forum Durango Appearance 2011 +
Tags for this Thread
