2009 Dodge Durango: AC/Heat will only come through main vents
Results 1 to 2 of 2
Thread: 2009 Dodge Durango: AC/Heat will only come through main vents
    Nov 2017
    1
    38234
    We cannot change to the floor or defrost. How do i tell ifs the control unit or the actuator?
    Durango Jedi Don Fox's Avatar
    Sep 2004
    Oxford, Ohio
    2,047
    100
    291 times
    Thayer:
    With the engine off, and key in the run position, listen for the sounds of the HVAC doors moving when you turn the know through its range of options. Can you get the temp to go from hot to cold, and back? If so, your blend door motor is working. While you are at it, check out the filter for the system accessed from under the rood on the pass side (IIRC).
    You may also look behind or under the glove box to be able to watch/hear the HVAC motors work as you turn the knob.
    de N8ECH
