getting awful hot AC
Results 1 to 6 of 6
Thread: getting awful hot AC
    Grasshopper AJWaller's Avatar
    Jan 2019
    Minot, ND
    55
    51416
    10 times
    2007 Durango SLT
    OK Finally warmed up a few days here in ND and tried out the AC.
    Clutch does not kick in.
    On my 99 intrepid it ended up being a low pressure switch. Can I be that lucky on my 07? Fuses all good, swapped relay with fuel pump as they was the same and vehicle fired right up so ruled out relay.
    Suggestions? comments? ideas to start next?
    Could if just be that low on freon? I know it has to run to get freon into the system but good ole google article I found suggested a way to actually get freon in when the system is to low and get enough it to cycle it on and off for a full charge...
    Thanks in advance
    Senior Member DuRonbo's Avatar
    Nov 2017
    Tiny Pebble, AR
    409
    37945
    124 times
    2008 Limited
    Ongoing
    Could be low on refrigerant. Need to put a set of gauges on it to accurately determine that.
    If there's a leak then adding Freon is just a waste of money. I'm guessing the A/C hasn't been run since last year? The compressor not running can be due to low charge, control issues or as you suggested the pressure switch. Either it's failed or the charge is low.
    2008 Durango Limited with every option available
    2004 Durango SLT (For Sale soon)
    2002 Chrysler 300m Special
    2000 Dodge Intrepid R/T
    Super Moderator tomk's Avatar
    Jun 2004
    Amherst, MA
    12,399
    16
    1568 times
    Definitely need to get a gauge on it and see if it is very low on freon before throwing parts at it.
    If it is low enough that the low-pressure cutout is open when the system is not running then the system is essentially empty, and possibly has air/moisture in it. You're gonna need a pro for this.
    IIRC in gen-IIs the low-pressure cutout is done by the AC pressure transducer.
    07 JGC Red Rock Limited 5.7L
    And some past Durangos
    de W1PF
    Durango Expert NumberThree's Avatar
    Mar 2017
    SW Florida
    886
    25201
    59 times
    2017 Durango SXT / 2012 Honda Pilot
    Window visors, 4 - 32G dashcams for 360 recording. 2M ham rig (calsign N4ZAW).RF shielded PCM.
    if it's not kicking-in, it could be the clutch solenoid, or maybe just a bad connection?
    From the land of the midnight sauna
    My Hobby Homepage
    Jan 2019
    Minot, ND
    55
    51416
    10 times
    2007 Durango SLT
    im thinking it is just so low that the low pressure switch isnt working. Got back home this morning and been raining so wasnt to bad a drive. Going to pull relay and run a jumper to hot and make sure it does kick on. Then can add some freon. Neighbor has gauges and such... Hopefully tomorrow. Will actually be driving this pig to and from work from now on (whopping 6 miles each way) as I accepted a job at home...
  7. #6
    Mar 2017
    SW Florida
    886
    25201
    59 times
    If it gets noticeably cooler when you first start it, or at highway speeds (at least, for the first few minutes), you may be on to the culprit with the low-pressure switch. Sometimes, you can whack them and they'll briefly start working again.
    But the same symptom can also be caused by the fans at the radiator. or a fouled evap core, because pre-2008's have no cabin filter. IKR!
    Anyhow, if the fans aren't running, they should be checked first, as they may be prone to failure like they are on the pre '08 Rams.. I replaced mine twice on my '02 Ram. At that time, I tracked mine down by disconnecting them, and jumping them to the battery. Finally in 2017, I traded the truck in due to that fouled evap core, which requires removal of the entire dash just to clean it.
    Regardless, it might be a good time to take the HVAC blower motor out (unplug, and remove the three #43 ithink torx head screws and it falls out), and stick a flashlight up inside to inspect the evap core fins for fouling, and clean the vanes on the blower's squirrel cage.
    My Hobby Homepage
  1. Replies: 1
    Last Post: 11-11-2018, 06:00 AM
  2. Anyone's 3rd gen awful in the rain?
    By silverunicorn in forum Durango Discussions 2014+
    Last Post: 10-02-2017, 04:15 PM
  3. Awful paintwork from factory
    By charliec in forum Durango Discussions
    Last Post: 03-26-2017, 03:49 PM
  4. Transmission Fuse Getting Hot '02
    By akawimp in forum Durango Discussions
    Last Post: 10-25-2015, 03:55 AM
  5. Dr side front breaks sticking and getting real hot
    By johnpat in forum Durango Discussions 1998-03
    Last Post: 06-24-2015, 11:35 AM
