2004 Durango 7-Pin Wiring Harness - D has no towing package
Results 1 to 6 of 6
Thread: 2004 Durango 7-Pin Wiring Harness - D has no towing package
    Jul 2005
    8
    770
    I have a 04 Durango without towing package but has factory coolers on it. I have a aftermarket hitch. Now here's my problem. I see a Dodge factory plug and go 7-pin wiring harness on the net. I assume this harness would work all the lights and have a blue wire for the controller I'm gonna wire. Does it require a hot wire ran to battery or have an in line fuse.
    Has anyone installed one of these and is it something I can do myself. I'm mechanically inclined but not strong on wiring.
    04 Durango SLT, 4.7L, 20" Ram Rims
    72 Challenger Rallye, 340 V8, Sassy Grass Green
    Sep 2005
    Savannah
    8
    821
    Did a 4 wire on a 2000 Durango last year. Mine came from Hopkins Mfg. through Wal-Mart. The directions that came with it were easily understood. The 7-wire shouldn't be too much more difficult.
    Sep 2005
    3
    830
    Putting in the Dodge 7 pin harness isn't bad
    I put the Dodge 7 pin wiring harness (and hitch) on myself. Both were really easy. The wiring harness plugs into both taillights (you have to take them out and plug the harness in line. You then run the wires to the front underhood fuse panel (it tie wraps along the frame) for power. There's a relay and a fuse (if I remember right) in the harness. Probably the hardest part (that I didn't do as my trailer doesn't have electric brakes) is run the wire into the passenger comprtment for the electric brakes (I just tie wrapped mine next to the maseter cylinder until I need it.) I have the instructions if you want to see them (it's only pictures, no words.)
    I got may harness from Wyckoff Chrysler ( www.wyckoffmoparparts.com) you get a discount plus use "PICACARD" in thr discount field when you check out and you get another 5-10% off.
    2004 Graphite Metallic Durango SLT.
    Jul 2005
    8
    770
    Pics would be good. Email to [email protected] if you don't mind.
    Thanks for the help.
    Sep 2005
    3
    830
    I scanned it in, but the Word file is 23 MB (and I'm on 56K dial up) so I'll try something else tomorrow. Maybe I'll try Acrobat.
    Do you have a pic of your Durango with Ram 20's? I have wanted to see what one looks like.
  7. #6
    Sep 2005
    3
    830
    Check your email, I remembered I could save it as HTML so it's a lot smaller (it should open with a web browser.)
    Enjoy!
  1. 2004 Trailer Towing
    By SQJunkie in forum Durango Discussions 2004-09
    Last Post: 07-03-2008, 08:06 PM
  2. liftgate wiring harness
    By bigred1307 in forum Durango Discussions 1998-03
    Last Post: 08-26-2006, 11:09 PM
  3. wiring harness can't connect to hitch w/ spare tire in place
    By michele_sabre_rider in forum Durango Discussions 1998-03
    Last Post: 03-23-2006, 07:05 AM
  4. 5.2 versus 5.9? Wiring harness question
    By Lil Red Truck in forum Durango Accessories 1998-03
    Last Post: 11-16-2005, 09:35 AM
  5. I need help! Towing Wire Harness Installation?
    By Rype in forum Durango Discussions 1998-03
    Last Post: 05-28-2005, 06:37 AM
Search tags for this page
04 durango trailer wiring
2004 dodge durango towing harness location
2004 dodge durango trailer wiring diagram
2005 dodge durango hitch and wiring
2005 dodge durango trailer wiring harness
