Brake issue
Results 1 to 2 of 2
Thread: Brake issue
    May 2019
    1
    53166
    Brake issue
    I have a 2000 Durango and have not had a problem with the brakes until recently. The brakes lock up just barely pushing the brake pedal, and it's actually getting scary to drive it now. The fluid in the reservoir is between the "Full" and "Add" lines so I know it's got fluid. I have/had intermittent ABS/Brake lights come on. Sometimes the dash is clear, other times it's the ABS light and rarely it's the ABS and Brake light. We have had a LOT of rain here in Kansas recently, and at first I thought it was just moisture on the rotors sitting overnight. However, I always do a "hard stop" in the mornings to clear the moisture, but the brakes still lock up after driving for 10+ minutes. It's getting to the point of letting off of the gas to idle stop, or riding the brakes before my turn. Either way, I can't hit the brakes in an unexpected event without coming to a screeching stop (someone cuts me off, kid runs out in the road, etc.)
    Super Moderator tomk's Avatar
    Jun 2004
    Amherst, MA
    12,442
    16
    1578 times
    Just guessing:
    If all four wheels are grabbing, the only thing I can think of is a problem with the booster..
    If only some wheels are grabbing, it might be a stuck parking brake cable or a flexible hose that has disintegrated inside.
    07 JGC Red Rock Limited 5.7L
    And some past Durangos
    de W1PF
  1. 2000 dodge D OBDII p0132/p0207 issue / AC issue
    By Raz_Daz in forum Durango Discussions 1998-03
    Last Post: 08-21-2018, 02:36 AM
  2. AC Issue / Warranty Issue
    By Randytenn in forum Durango Discussions 2014+
    Last Post: 07-24-2016, 11:06 PM
  3. Brake issue on an 01
    By RJL in forum Durango Discussions 1998-03
    Last Post: 11-21-2009, 06:28 PM
  4. Not your usual ABS/Brake light issue?
    By 99Rangoaz in forum Durango Discussions 1998-03
    Last Post: 06-03-2008, 06:01 PM
  5. Brake issue
    By biggame in forum Durango Discussions 1998-03
    Last Post: 10-30-2006, 09:43 AM
