2002 Dodge Durango Build
Results 1 to 5 of 5
Like Tree1Likes
  • 1 Post By OrdieJay
Thread: 2002 Dodge Durango Build
    Grasshopper OrdieJay's Avatar
    Mar 2019
    Kuwait
    7
    52452
    2 times
    2002 Dodge Durango SLT 5.9L V8
    All,
    I am an American contractor working in Kuwait and I just purchased a 2002 Dodge Durango from another contractor that was leaving the country. I paid about $1300 for it about 2 months ago (1 Feb 2019). I've ridden in it multiple times and drove it once. It didn't have A/C when I borrowed it a few months prior, but apparently he got the compressor replaced and it now has A/C, which is an absolute must here in Kuwait. I remember the ride being a little bumpy, but the engine was fantastic! That big V8 would haul a$$! I looked it over when I agreed to buy it and it seemed like a decent vehicle that would get me to and from work. I paid him cash for it and we agreed that he would keep using it until he left the country. During that time (roughly about 2 weeks) he was in an accident and wrecked the right front end. He paid for it to be fixed, but it looks like they didn't do a very good job.
    The hood doesn't line up right, so I'll have to take a look at that.
    This pic is where they glued up the headlight and taped it until the glue tried. I'll have to try to get off that glue residue with some goo gone.
    This pic is of the broken headlight. We got some rain here in Kuwait the past week and some water and dirt got inside the headlight. I've ordered a set of headlights from Amazon.com, but unfortunately they can't be shipped here. I had to get them shipped to my mom and get her to mail them here.
    The guy paid for the truck to be fixed and it still looked decent. He asked to use the truck to mail off some packages and I get a message from him shortly after saying that a car side swiped the truck and he was gonna get them to pay for it.
    Apparently, it just needed to be buffed out.
    I guess it doesn't look that bad.
    I gave they previous owner cash for the vehicle in January and he was gonna continue driving it until he left on Feb. 1, 2019. Well, he left and I took possession of the truck and took another look around. There is some grinding noise coming from the front right wheel when I turn the wheel and reverse. I might need some wheel bearings or something... I won't know until I get in there and pull the tire off. There seemed to be a lot of cosmetic things wrong with the truck, but that didn't bother me. I figured I'll get everything fixed up over time, as long as the drivetrain is in good working order, everything else could wait.
    Heres a couple pics of the truck.
    IYAOYAS
    Mar 2019
    Kuwait
    7
    52452
    2 times
    So after driving the truck for a few days the driver side window stopped working. It made some weird growling noises at me when I used it before, but I thought that maybe there was some dirt or something inside. Nope, that thing was so pissed off that it started eating itself.
    I absolutely hate working in the dark, but I had to figure out the problem so I could get it fixed ASAP. Kuwait hardly gets rain, but this year has been pretty bad. There's been flooding and all sorts of weird weather going on this past year, so I needed to get this window working.
    Like I said, the window regulator started eating itself. The white plastic piece that goes inside the spring guide was torn apart and chunks were missing. I thought I'd be able to glue some stuff together until the new regulator came in, but that was not an option after looking at the disaster I pulled out. I found a wooden stick in the bushes and replaced the regulator with that. It's not OEM, but it'll have to do until I get the new part.
    BAD! BAD! BAD!
    Well, after about 9 days of waiting I finally received the new part and took the 1 screw out of the door panel and replaced that damaged window regulator. I figured I'd do it in the daytime...
    So, it went in pretty easily. Took about 10 minutes to get it installed, the window seems to be working now. Sorry I didn't get a pic of the new regulator, but I was too excited to put it in. I did get a video of it working though.
    NumberThree likes this.
    IYAOYAS
    Mar 2019
    Kuwait
    7
    52452
    2 times
    One of the main things that really bothered me was the rear trunk cargo area. The wood was was broken/missing which left a big gaping hole in the cargo area. Everything would fall in there and get lost or my toolbox slide in there and then tip over. It was a huge pain in the a$$. I had to do something about this!
    I found a piece of plywood laying around, so I took some measurements and then took my jigsaw to it. It's not perfect, I just kind of eyeballed it as it would be covered with carpet anyway. The carpet would fill in any gaps that were there.
    One of the hinges was missing and the clips that hold the hinges to the metal part in the trunk were broken. I glued the hinges to the metal using permatex black adhesive. It should hold it in place, not like I open that thing everyday or anything.
    I cut the hole for the latch and drilled screw holes for the hinges. I even took my forsner bits to the bottom side to make the attaching hardware flush with the plywood.
    I then cleaned it up and sprayed it with the Rustoleum Undercoating spray, just so it didn't have that plywood look to it. I think it had some laminated particle board in there before.
    I attached the carpet to the plywood using some 3M Spray Adhesive and a little prayer. I don't have a staple gun, so I can't get the edges to stick to the plywood. It looks like they used staples before, because I had a hell of a time pulling each and every staple out of the carpet.
    It's not pretty, but it works. I'll eventually find someone with a staple gun or break down and buy one. I have one back home in the States, but it's in storage and don't really want to ask my mom to go rummage around my stuff to find a staple gun and then pay the shipping fees to mail it here. I mean, it works... Holds my stuff upright and doesn't shift around. I don't have to toss my toolbox all the way in the back when I load it up. Btw, I use my toolbox at work, then I take it back to the apartment with me everyday. I used to leave it there and lock it up, but I own a Dodge now, so I better keep some tools handy. lol
    Till next time...
    IYAOYAS
    Mar 2019
    Kuwait
    7
    52452
    2 times
    Leaking Wheel Cylinder, Broken Self Adjuster and Brake Shoe Replacement
    I started driving the truck to work and noticed there was something wrong with the brake pedal. I stepped on the pedal and it would go all the way to the floor before it would slow down and eventually stop. I took it to the shop and the mechanic there told me that the brakes needed to be bled. He bled the brakes, put more glue on the headlight, and charged me $70 for everything. I start driving and there's a little difference in the brakes, but not much. He also said, that if it doesn't get better that I will need a pump. Don't know what pump he's talking about, but whatever. I keep driving it for a few more days with no change in the brakes. So a few days later I noticed some fluid coming from the right rear brake drum.
    I removed the tire to do a little inspection...
    Here's a pic of the tire that's covered in brake fluid fluid from the leaking wheel cylinder
    Pic of the leaking wheel cylinder. I'm assuming that the air in the system was coming from the leaking wheel cylinder.
    A pic of the replacement parts I ordered from AutoZone.com. The driver side mirror is broken and is a safety issue, so I purchased the replacement glass (which was the wrong one!!). The door has this awful squeal when I open the door and I cringe every time I open or close the door, so I purchased new hinge pins and bushings as well.
    I pulled the old wheel cylinder out and replaced it with the new one from Autozone.com
    After installing the new wheel cylinder, I began bleeding the brakes. I started with the right rear (furthest from the master cylinder), then I removed the rear left tire and began bleeding the air out of that line. The brake pedal was still going all the way to the floor. I was puzzled by this and so I removed the drum rotor and noticed the self-adjuster cable was broken.
    I also noticed the brake shoes were cracked. I wasn't sure if this was normal, so I did a google search and people were saying that they might crumble over time and i wouldn't have anything left of my brake shoes. I ordered brake shoes and a wherever self adjuster kit from Advanceauto.com. I waited about 9 days for them to arrive and still had squishy brakes. Was hoping that replacing the leaking wheel cylinder would fix the squishy brake problem, but at least it wasn't dumping brake fluid everywhere and stuttering when I stop suddenly.
    I installed the brake shoes on the "good" side that had the leaking wheel cylinder and took pictures of the self adjuster and how it was installed, so I can try to put the other side back together correctly, I tell you, the self adjuster is a pain in the a$$. It took a little while to get it installed and I was running out of time, so I didn't take any pictures of the install. However, I did get pics of how it was supposed to go together.
    So when I was replacing the brake shoes I ran into an issue removing the little clips that attach the parking brake to the brake shoe. Is the actual part that goes on there and what is it called? I had a hell of a time removing it and replacing it. Looks like someone just put a piece of metal and wrapped it around the pin. Hope it stays on there!!
    That was the first time I had ever pulled apart drum brakes and replaced brake shoes, hope I never ever have to do that again. I took it out for a test drive and everything seems to be in good working order. The brakes feel absolutely amazing and the pedal doesn't go all the way to the floor. It was a lot of work, but I'm glad that part is over. I wish I had ordered new spring kits for both sides and another wheel cylinder for the rear left side, so I won't have any issues. I'll check that off the list and move on to the next project.
    IYAOYAS
    Mar 2019
    Kuwait
    7
    52452
    2 times
    2002 Dodge Durango Driverside Hinge Pin Replacement
    The driver side door sounds like it’s gonna fall off every time I open or close it, so I decided to replace the hinge pins. I had never replaced hinge pins before in my life and I hope I never have to do it again. I don’t think it’s right and I’m not sure what else I need to do to fix the problem completely. If anyone has any suggestions, I’m open to it.
    Here’s a video of what I was dealing with... notice the hinge pin bushing was bent and crooked.
    Still squeaks, but not as bad.
    Here’s a few more pics of the installation.
    This is the hinge pin I purchased from Auto Zone for $19.99. Doorman Hinge Pin P/N: 38403
    Not sure how these things are installed from the factory, but I had a hell of a time removing it. Apparently, they’re pressed on each end and so I had to cut the pin. The only thing I had that would cut it was my jigsaw and a metal cutting blade.
    A pic of the bent bushing that I thought was making all the noise.
    I installed the new copper bushing and was ready to put everything back together. Installing this little spring was pretty damn frustrating. Every time it fell it would get lodged into a little crevice and I had to use a magnet to get it out.
    I had to remove the door from the hinge to get that spring back in. I found it pretty difficult to get everything lined up afterwards.
    I got the hinge pin installed, spring back in its place, and I put the retaining clip in place. I had to hit the hinge pin a bit so it would sit flush with the hinge and install the retaining clip. I lined up the door the best I could and it still kinda squeaks and the door might be a little off. I’ll have to fix that later when I have more time.
    Till next time....
    Attached Thumbnails Attached Thumbnails 2002 Dodge Durango Build-8e8de573-ca93-49c0-844b-f5da9d2315b6.jpg
    IYAOYAS
  1. MoparMike's 2015 Dodge Durango R/T SQ Build
    By MoparMike in forum Durango Electronics 2011 +
    Last Post: 12-07-2018, 07:35 PM
  2. 2002 dodge durango slt plus door locks not working
    By 02durango1 in forum Durango Discussions 1998-03
    Last Post: 01-23-2014, 07:36 AM
  3. 2002 dodge durango 4.7 running hot at highway speed's
    Last Post: 01-03-2014, 04:25 AM
  4. 2002 Durango Build (updated 10-06)
    By NonEvo in forum Durango Discussions 1998-03
    Last Post: 10-06-2006, 02:58 PM
  5. 2002 4.7 Dodge Durango vs 2004 4.7 HO Jeep Cherokee
    By Durango_Traveler in forum Durango Discussions 1998-03
    Last Post: 09-30-2005, 02:17 PM
