wiring harness can't connect to hitch w/ spare tire in place
Results 1 to 9 of 9
Thread: wiring harness can't connect to hitch w/ spare tire in place
    Grasshopper michele_sabre_rider's Avatar
    Jan 2006
    15
    999
    I posted this within another topic thread, but it may have gotten lost in the shuffle?
    I installed my wiring harness for my trailer hitch however I can't connect it to the hitch because the spare tire is in the way of the connector box on the hitch itself. is there some sort of adapter that I can use to lengthen this connector so I can plug the harness in around the spare tire underneath?
    my hitch looks just like kevin_rants in this thread --> http://durangoclub.com/forum/viewtop...9508c48d5c719b
    any ideas??
    Durango Expert
    Dec 2005
    York, PA
    673
    929
    You could just cut the wires and extend them with butt connectors, crimpers, and some wire
    Man I miss my Custom 2001 Durango R/T
    2005 Nissan Altima 3.5 SE
    Aug 2005
    Antarctica
    15,095
    807
    128 times
    Rick, is that Westin Bull Bar new?
    IndyD
    Durango Expert
    Dec 2005
    York, PA
    673
    929
    Yes it's. I just put it on. You like?
    Aug 2005
    Antarctica
    15,095
    807
    128 times
    Quote Originally Posted by BigRick01R/T
    Yeppers. It looks nice and classy on your D. Congrats!
    I like it better than the moose killer style that wraps up over the headlights.
    I went with the Westin Safari Bar because I wasn't sure about the skid plate on the Westin Bull Bar. I didn't know if it would look heavy or out of place. In your photo, it looks real nice.
    Easy to install?
    IndyDurango
  7. #6
    Durango Jedi Volphin's Avatar
    Sep 2004
    Big Orange Country
    2,081
    89
    2 times
    Harness
    You mean the harness is too short? Mine came with 3 feet of extra harness? I'd check your harness routing and see if you can pick up some more slack. Also, if interference with the tire is a problem, loosen the spare and push it toward the front of the D while a buddy winches it back up. You can make some extra connection space that way. I had the spare out when routing my harness, come to think of it.
    2001 SLT Plus, 5.9L, PPH Headers, MP 1.7 RRs, M1, and VCs, Fastman 52mm TB, B&G Flash, PIAAs, Go Rhino Guards, Tow Pkg, Mag-Hytec Diff & Trans Covers, IP CAI, MOAB Basket, '03 Front Brakes with drilled and slotted rotors and much much more!! Ask your doctor if the Durango is right for you.
  8. #7
    Jan 2006
    15
    999
    Quote Originally Posted by Volphin
    oh no, I have plenty of slack too - that's not the problem.
    Quote Originally Posted by Volfin
    I wasn't aware that the spare could be moved into another position, I thought it was in a "niche" up there. I could give that a try.
    what happened when you put the spare back up? did you have a problem with the harness in place? maye I can just remove the spare, hook up the harness and then put the spare back up?
    than Q!
  9. #8
    Durango Expert
    Dec 2005
    York, PA
    673
    929
    1000% easier to install over the Mopar one. Not as heavy either. I love the look of it. I also have the side rails (chrome.) I installed one and didn't like it. But since I'm going to lower it, I left one side on so I can compare after the drop.
  10. #9
    Sep 2004
    Big Orange Country
    2,081
    89
    2 times
    Wiring
    When it goes back up you have some wiggle room. Not much, but some. Just push the tire forward before it seats. It should fit fine. You'll need that spare one day? so I wouldn't do anything rash.
    Bill
  1. Oversize tire/spare tire question
    By Silent One in forum Durango Discussions 1998-03
    Last Post: 10-15-2010, 06:31 PM
  2. Trailer hitch wiring
    By greendurango in forum Durango Accessories 1998-03
    Last Post: 12-09-2007, 08:25 AM
  3. liftgate wiring harness
    By bigred1307 in forum Durango Discussions 1998-03
    Last Post: 08-26-2006, 11:09 PM
  4. 5.2 versus 5.9? Wiring harness question
    By Lil Red Truck in forum Durango Accessories 1998-03
    Last Post: 11-16-2005, 09:35 AM
  5. 2004 Durango 7-Pin Wiring Harness - D has no towing package
    By cec311 in forum Durango Discussions 2004-09
    Last Post: 09-14-2005, 10:00 PM
