problems
Results 1 to 4 of 4
Thread: problems
    Junior Member
    Sep 2004
    Vallejo,CA
    140
    185
    problems
    Hello all
    My dad has a new 2500 heavy duty Ram with the 5.7 Hemi he's having a few problems with it. one problem that he's and the dealer said is fine is when we starts out driving in first gear going into second gear he's a howling noise sometimes it last for a few seconds to a minute. any info that anyone can share with be grateful
    thanks
    Durango Jedi Silver Ghost's Avatar
    May 2004
    Upstate NY
    2,057
    5
    5 times
    This doesn't seem normal to me. Does it only happen when the engine is cold? Maybe it has to sit at the dealer overnight.
    I have the same set-up (2500/Hemi) and it's smoth as silk.
    You might try another dealer or have your Dad test drive the truck with the mechanic going along under the same conditions that you notice the problem.
    Joe
    Durango Expert Big Al's Avatar
    Sep 2004
    Durham NC
    896
    74
    3 times
    1998 5.2, 4x4, SLT
    Your description sounds exactly like the infamous "clutch fan" roar so many D owners have complained about??
    On the D this roaring, along with the "real" loss of approx. 20 hp to drive the clutch fan when it's engaged, made it "seem" like the transmission was slipping on the shift between 1st and 2nd gear. (i.e. it sounded like the engine was reving way too high before shifting to 2nd)
    If this is what's happening, then the dealer's right?the roaring sound is normal whenever the clutch fan is engaged! This "usually" occurs when you first drive off after the engine's not had a chance to completely cool down since it was shut off or whenever it's been "real" cold outside (because the viscous fluid in the fan clutch gets thick)
    Junior Member
    Sep 2004
    Vallejo,CA
    140
    185
    thanks for the help
    its not the clutch fan. I believe it happens when it's cold or when it sit for a while after driving. he's had the mechanic ride with him and they said they fixed the problem but you can still hear it
  1. Possible problems with 99 PCM
    By dizzyD in forum Durango Discussions 1998-03
    Last Post: 02-20-2013, 01:45 AM
  2. A Few Problems?
    By OverKill in forum Durango Discussions 1998-03
    Last Post: 01-07-2010, 07:47 PM
  3. 03 SLT 4.7 problems
    By chad w in forum Durango Discussions 1998-03
    Last Post: 02-05-2009, 09:11 PM
  4. D problems
    By Ironworker711 in forum Durango Discussions 1998-03
    Last Post: 02-12-2008, 10:39 AM
  5. Got my new BJ's and now more problems!!
    By odie in forum Durango Discussions 1998-03
    Last Post: 12-22-2004, 03:26 AM
