Platinum plugs in a Hemi??
Page 1 of 2 12 LastLast
Results 1 to 10 of 16
Thread: Platinum plugs in a Hemi??
    Nav
    Nav is offline
    Durango Expert
    Jun 2004
    Queensbury, NY
    872
    14
    9 times
    2011 Ram Crew Cab
    About to replace plugs at 32K in a Ram Hemi and my mechanic is suggesting double platinum plugs good for 100K. A friend has a 4.7 Dakota and he says platinum isn't recommended in his engine. I'm wondering if any such restriction applies to the Hemi. Any suggestions/comments appreciated. TIA
    Pete 09 Ram 1500 QC
    Durango Jedi Master
    Jun 2004
    Fontana, CA
    7,596
    12
    232 times
    If your only consideration is cost, just put in some stock Champions (non-platinum) or the Autolite eq. If you're looking for the finite gains of better plugs for mileage or performance, you can go the very expensive way of the E3 plugs.
    Nav
    Nav is offline
    Durango Expert
    Jun 2004
    Queensbury, NY
    872
    14
    9 times
    2011 Ram Crew Cab
    Well, what I'm trying to avoid is the expense of changing plugs every 30K. The double platinum plugs are only $2 more each compared to non-platinum which translates into a large savings over time since they're good for 100K. I'll check out the E3 plugs.
    Thanks Mike.
    Pete 09 Ram 1500 QC
    Durango Guru Don Fox's Avatar
    Sep 2004
    Oxford, Ohio
    1,284
    100
    54 times
    Mike:
    Although platinum plugs aren't recommended by Dodge for the 4.7 or 5.7 engines, you can run them. I ran a set in my 01 4.7 for 50k and was very pleased with them. I understand that entities such as police, fire, taxi, etc, have gone to platinum plugs in some cases due to their extensive idle time.
    Whatever you do though, make sure a bit of no seize goes in there and, if it takes more than 4 -5 years to hit the 100k, I'd pull them based on time and not mileage so that you know they WILL come out. I've heard that when Ford and GM first went to the 100k plug interval, they didn't foresee some folks leaving the plugs in for 7-10 years and sometimes a plug or two would freeze up or strip when removal was attempted.
    Just some food for thought. Also, unless you run the truck hard or idled extensively, the OEM plugs will probably go another 10-15k if need be.
    Nav
    Nav is offline
    Durango Expert
    Jun 2004
    Queensbury, NY
    872
    14
    9 times
    2011 Ram Crew Cab
    What I'm reading is that the platinums have a higher resistance than stock plugs and, as a result, overheat and burn out the coil packs. Research continues. The E3's get mixed reviews as well.
    Pete 09 Ram 1500 QC
  7. #6
    Durango Jedi Master
    Jun 2004
    Fontana, CA
    7,596
    12
    232 times
    True, our older ignitions tend to drop when added resistance is put into the equation. I haven't heard enough about the Hemi/4.7 coil per plug setups as far as longevity problems to get a feeling for them, however, if they're built to the same quality as the old style coils, I'd have my doubts about them.
    The E3 plugs are almost 4 times more than an Autolite eq but they do show marginal but measurable fuel savings over standard plugs and better emissions than a standard new plug from anybody else. As a matter of fact, I have a set of E3's I just put into my D to see how they rate for myself. Will let you know on how they turn out. I'm a great believer in the cheap plugs and 15k change outs, but we'll see.
    I have to say these are the first plugs that I've ever seen that say not to gap them right on the box. It'd be rather difficult to do anyway with their design. I've seen real time shots of these plugs in comparison to conventional plugs and the flames spread is remarkably better with the E3. Emissions testing also show real differences in the amount of fuel need for a set rpm with the E3 being much less. That means cleaner burning and better emissions for us.
    Time will tell.
  8. #7
    Super Moderator tomk's Avatar
    Jun 2004
    Amherst, MA
    11,030
    16
    1046 times
    Based on looking at the plugs when I did 'em in my 5.7L at about 36K, I don't think platinums are gonna make one whit of difference.
    All platinums do for you is reduce electrode wear. When I pulled my plugs, about half of them had a pretty heavy tan deposit on the insulator (probably 1/8" thick on some) and I think that's what the change interval is about. The electrodes looked like new and the gaps were about .004" wide on average. Based on that criteria, they could easily go another 36K.
    I ended up putting Autolite 'double platinum' plugs in only because I could get them easily and they didn't run any different than the plugs I pulled out. At the current mileage rate, it'll be another year before these get pulled for a look-see.
    I don't think true platinum plugs (with a platinum pellet on the center electrode) will have any effect on the coils. The platinum plugs that have a wire center electrode might though, I can see how those could have different current characteristics.
    ?tom
    What?
    07 JGC Red Rock Limited 5.7L
    And some past Durangos
    de W1PF
  9. #8
    Nav
    Nav is offline
    Durango Expert
    Jun 2004
    Queensbury, NY
    872
    14
    9 times
    2011 Ram Crew Cab
    OK, so I guess what I'll do is put in 5 stock plugs, 5 platinum, 5 E3's and leave one original plug in.
    Pete 09 Ram 1500 QC
  10. #9
    Sep 2004
    Oxford, Ohio
    1,284
    100
    54 times
    Mike:
    All I've got to say is talk about being inclusive! With a decision like that, you should either be a Pollytician or work at a university
    Don't forget now, if we REALLY want to do this right, we now need to form a committee and then mull it over for a month or so!
  11. #10
    Jun 2004
    Amherst, MA
    11,030
    16
    1046 times
    Pete, make sure you place the various plugs in statistically-valid positions so that we can get useful data from the experiment
    What?
    de W1PF
  1. Spark Plugs on 2008 5.7L Hemi?
    By all_bran in forum Durango Discussions 2004-09
    Last Post: 06-16-2014, 06:02 PM
  2. Replies: 0
    Last Post: 06-17-2011, 05:29 PM
  3. The Platinum Syndrome
    Last Post: 01-15-2008, 09:45 PM
  4. Champion RC12PYP platinum plugs
    By Don Fox in forum Durango Discussions 1998-03
    Last Post: 09-12-2007, 07:03 PM
  5. Bosch Platinum + 4 Spark plugs
    By Wile E in forum Durango Discussions 1998-03
    Last Post: 02-21-2006, 04:01 PM
Search tags for this page
anybody use autolite xp5325 plugs in their hemi
best spark plug for 2004 dodge ram hemi
best spark plug for 2012 dodge ram hemi
best spark plugs for 2012 dodge ram hemi
spark plugs 2004 hemi truck
