Sway issues 2016 RT AWD and Travel Trailer - Page 2
Page 2 of 6 FirstFirst 1234 ... LastLast
Results 11 to 20 of 53
Like Tree12Likes
Thread: Sway issues 2016 RT AWD and Travel Trailer
  1. #11
    Durango Jedi
    Feb 2014
    Atlanta
    2,319
    3912
    344 times
    Yes we tried towing without any WD hitch and it was the same basically.
    OK, this tells me we really need to measure the tongue weight to make sure we are in the 10-15% range of the total trailer weight...and closer to 15% with it being a TT.
    If we are not in this range the WDH does nothing to help.
    Another thought is to tow a sister-ship to your model and see if we have the same problem to eliminate a possible assembly defect of trailer.
  2. #12
    Durango Jedi
    Feb 2014
    Atlanta
    2,319
    3912
    344 times
    How to Measure Tongue Weight - wikiHow
    You can measure it with a bathroom scale, so not sure how your trailer dealer can't do this and make the proper adjustments.
  3. #13
    Durango Jedi
    Feb 2014
    Atlanta
    2,319
    3912
    344 times
    Here's a better visual on how to perform this and tools required.
    I bought a HD scale from Amazon for about $40 that can handle up to 550 lbs.
    https://www.etrailer.com/faq-how-to-...ue-weight.aspx
  5. #14
    May 2017
    Central Florida
    23
    28481
    1 times
    2016 Durango RT AWD
    Quote Originally Posted by Chase300 View Post
    They actually towed it with another vehicle and had no problems but that would be a way of seeing if it might be my Durango. They could tow a similar weight/length trailer with different layout that likely has a heavier tongue weight.
    That's a lot of math, lol. I'd have to get a different scale, our is glass.
    I guess they told my wife they could take it to a commercial scale, not sure why they didn't do that because the literally spent the whole day trying different things.
  6. #15
    Durango Jedi
    Feb 2014
    Atlanta
    2,319
    3912
    344 times
    See the link in post #13.
    2016 RT likes this.
  7. #16
    May 2017
    Central Florida
    23
    28481
    1 times
    2016 Durango RT AWD
    I saw it but the trailer is at the dealer right now. I'm going to have them get the tongue weight measured and go from there. Either way I'm picking it up tomorrow and will work on it this week. I have a 55 gallon plastic barrel I can put water in. I can put it in the bedroom area and add water until it either doesn't sway or I give up and buy a truck. I'm thinking the air spring helpers will raise up the rear of the Durango and stiffen the suspension while towing so I don't have to put as much tension on the WDH to help with sway.
  8. #17
    May 2017
    Central Florida
    23
    28481
    1 times
    2016 Durango RT AWD
    I looked up the trailer specs and it says the tongue weight it 625lbs dry, the trailer weighs 5728lbs dry. If I add the two batteries that's another 100lbs and the hitch weighs just under 50lbs. That bringing the tongue weight to 775lbs. We don't have much in the front storage area but by the gears specs it's just over 100lbs making tongue weight 875lbs. Adding the additional 150lbs of gear weight to the dry weight of the trailer, plus maybe 100lbs of miscellaneous gear inside brings the gross weight to 5978lbs. 10% is 597lbs and 15% of the that is 896lbs. I know I'm assuming the specs of the trailer reflect the accurate tongue weight and I'm relying on published weight specs for the batteries, etc, but even if it was off 100lbs either way I'd say we are within the range it should be, give or take a few pounds. I still plan to have them get an accurate weight, hopefully I'm off an it is a weight issue.
  9. #18
    Super Moderator MJB8's Avatar
    Jul 2013
    933
    2410
    325 times
    2013 Redline R/T: HemiFever Tune, CORSA, Billet Tech CC, AFE CAI, 20% Tint, 22x9 SRT Reps, BREMBOS
    propane tanks on the nose size ? full or empty?
    2013 RedLine R/T. 22" SRT REP, SRT Brembo 6/4 Calipers/Drilled & Slotted Rotors, 15% Tint, LEDS. 430N, Tow Package ,Sunroof. AFE CAI, Diablo Trinity, Hemifever Tune,180 TStat, Fastman 85mm TB w/backcut, Billet Technology's Catch Can, Corsa Cat back, RK Sports Ram Air Hood.
  10. #19
    Junior Member HDB0B's Avatar
    Mar 2017
    S.E. PA
    100
    25017
    11 times
    2014 Durango SXT
    You are on the right path!
    Bob
  11. #20
    May 2017
    Central Florida
    23
    28481
    1 times
    2016 Durango RT AWD
    Quote Originally Posted by MJB8 View Post
    Yes, they are on the front and are full but, the trailer specs include the tank weight.
  1. Towing with my Durango. Will this travel trailer be ok?
    By jagermeister in forum Durango Towing
    Last Post: 01-06-2017, 07:18 AM
  2. Travel trailer towing with 2015 durango
    By Crystalmw in forum Durango Towing
    Last Post: 08-01-2016, 07:55 PM
  3. 2016 Citadel AWD Hemi Alignment issues
    By cazzz in forum Durango Discussions 2014+
    Last Post: 06-09-2016, 07:45 AM
  4. What is the longest Travel Trailer you can tow safely?
    By JJgreenD in forum Durango Towing
    Last Post: 07-17-2013, 05:17 AM
  5. Sunline Travel Trailer For Sale
    By Silver Ghost in forum For Sale
    Last Post: 02-01-2007, 09:14 PM
