AC Problems
Results 1 to 3 of 3
Thread: AC Problems
    May 2016
    1
    12588
    AC Problems
    my 2001 Durangos' a/c wad blowing warm air in the front vents but cold from the rear..after thourgh research I determined the problem was the expansion valve. After replacing the valve and recharging the system the front cooled like a champ but the rear was blowing warm..any suggestions?
    Durango Guru Citadel Brian's Avatar
    Jan 2014
    New Jersey
    1,343
    3771
    315 times
    Do you need to do anything special when your dealing with a front and rear AC during the recharge process??
    2014 White Citadel 5.7 loaded except for DVD
    2007 Jeep Grand Cherokee 5.7 Limited QDII
    1968 Pontiac Firebird 350 4spd #'s matching
    2003 HO Cummins Ram 6spd QCSB sold.
    Grasshopper texashale's Avatar
    May 2016
    2
    12556
    Every time I open an AC system, I replace everything because it is almost guaranteed that the next weakest thing in the system will break, and on and on. My suggestion is that you get all the parts for the entire system and replace them all. Don't forget all the seals too... It sucks, but that's my two cents...
    Sent from my Z955A using Tapatalk
  1. Please help no bus big problems
    By coryfarrell90 in forum Durango Discussions
    Last Post: 05-04-2016, 06:40 PM
  2. a/c problems
    By rcadvanced2 in forum Durango Performance 2004-09
    Last Post: 12-31-2014, 01:15 AM
  3. Possible problems with 99 PCM
    By dizzyD in forum Durango Discussions 1998-03
    Last Post: 02-20-2013, 01:45 AM
  4. A Few Problems?
    By OverKill in forum Durango Discussions 1998-03
    Last Post: 01-07-2010, 07:47 PM
  5. D problems
    By Ironworker711 in forum Durango Discussions 1998-03
    Last Post: 02-12-2008, 10:39 AM
Search tags for this page
dodge durango ac problems
