Hellcat Throttle Body
Page 1 of 2 12 LastLast
Results 1 to 10 of 11
Like Tree6Likes
Thread: Hellcat Throttle Body
    Junior Member DD2015RT's Avatar
    Jun 2016
    Texas
    164
    12928
    50 times
    15DDRT
    2.9 Whipple SC | ARH 1 & 7/8 Headers & Pipes (no cats) | Alchy 100% Meth Kit
    Had this thought broached to me today with my whipple supercharger. Figured if I'm going to do it... Do it before I get it tuned again here on 1/20/17. They do exist, and work on the 5.7. What are your thoughts?
    Hellcat 95mm Throttle Body Adapter to 5.7L 6.1L HEMI Intake by Modern Muscle - Modern Muscle Xtreme
    https://www.thefastman.com/throttlebodiesHemi.php
    DD15-R/T-RWD
    Senior Member
    Mar 2016
    West Michigan
    408
    12276
    120 times
    2016 Brilliant Black Dodge Durango Limited Blacktop Edition
    On my turbo vehicles, the throttle body was noticable but not as much as exhaust or cams. Naturally Aspirated get choked down the most by throttle bodies, because they suck for performance (pun WAS intended). But seeing as the supercharger is on the engine side of the throttle body, I'm not sure. You know if the hole in the Wipple's flange is even that large or will you have to port that to reap the true benefit? (shavings + Wipple = DANGER).
    You are cramming air into the motor, with force, but its trying to basicly free flow out the tailpipe aside from what little force the exhaust stroke gets. Headers and large exhaust would help create a more suction on the exhaust ports know as scavenging.
    The cams with differant lift/duration allow more air to flow in and and open the exhaust earlier to help evacuate it. Scavenging would suck on the cylinder helping the piston come up faster improving engine response, AND with the overlap the intake will open while exhaust is still open briefly and SUCK the intake change in a bit more by "overlapping". Overlap is also what gives that trademark "muscle car idle".
    Personally if I was you, which I'm not, I would go with this cam to perk up that "weak" range on your dyno sheet I seen under 2,400RPM, some long tube headers, corsa, etc. Cam would require of R&R (Remove&Reinstall) of the Wipple unfortunately.
    5.7L HEMI VVT Performance S/C Camshaft by Modern Muscle - Modern Muscle Xtreme
    HEMI MDS Delete Kit by MOPAR
    HEMI VVT Limiter
    End of my $0.02
    DD2015RT likes this.
    Jun 2016
    Texas
    164
    12928
    50 times
    15DDRT
    Quote Originally Posted by Tweak View Post
    HEMI VVT Limiter
    End of my $0.02
    Thanks for the reply, I believe I understand what you've said - the cam stuff I need to learn more about. I should of mentioned I have the ARH 1 & 7/8 headers with a no cat straight pipe. Furthermore I did ceramic coating on the whole kit to not only reduce engine bay heat but to push out exhaust/heat faster. Part of my research led me to determine the pushing of air in via the whipple sc, that I needed a good exit via the exhaust - the ARH heads. I did the 7/8 rather than the 3/4 due to future planned mods (financial dependent, lol).
    This TB, going to get confirmation, is a straight replacement to the stock one. Same fit.
    I don't know how costly it would be to do the cam install. The TB would be a quicky, yet not a complete super expense. This is something I feel comfortable installing myself where I'd have to pay for the cam.
    DD15-R/T-RWD
    Durango Guru Bryali's Avatar
    Sep 2013
    Central Louisiana
    1,046
    2760
    493 times
    2014 Dodge Durango RT AWD
    Whipple 2.9L Supercharger, Magnaflow cat-back, Tuned by Peitz Performance Tunes
    Quote Originally Posted by DD2015RT View Post
    I would not be surprised to see $1000-1500 for a cam/lifters install. These engines require the heads to come off to get to the lifters. It is not a quick or easy job and that's without having a blower to deal with. If you're going to consider a cam swap I would HIGHLY recommend just having the bottom end forged at the same time since everything is going to be taken out anyway. I don't know if I am willing to pay for a set of expensive heads but it probably wouldn't hurt to have your OEM heads freshened up with a basic port/polish job at your local machine shop. Any new cam/lifter kit should also include upgraded springs so (again) you might as well do it all while you're in there. Just my thoughts on that....
    The Whipple already has an adapter to mount your OEM TB to the Whipple snout and it tapers from the 85mm OEM TB to the giant opening inside the Whipple. You should call Modern Muscle to make sure you get whatever correct adapters you need. You don't want to go from the 95mm Hellcat TB to the 85mm OEM adapter to the Whipple snout. With that said, I would do the HC TB before you get tuned. It's a bolt-on mod that you'll see a benefit from, unlike people with completely stock NA un-tuned motors bolting on a ported TB and claiming ridiculous HP gains. Let me know how it works for you. I'm about to sell my house and I may be able to convince my wife to spend the money on a TB for ours.
    DD2015RT and Tweak like this.
    -Bryan
    2014 Durango RT: Road Magnet springs, 2.9L Whipple, Magnaflow cat-back, ARH LT headers, tuned by Peitz Performance Tunes (No Updated Time Yet)
    2006 Charger SRT8: Nitrous Outlet plate w/ 100hp shot, Paramount trans and 2800 converter, Getrag 3.91, tuned by Peitz Performance Tunes. (11.809 @ 116.15 mph)
    Durango Guru
    Feb 2014
    Atlanta
    1,858
    3912
    244 times
    I have seen benefit on Whipple superchargers installed on 8.2L GM engines swapping out the factory TB for a larger Whipple TB. Better response and power...though the better throttle response the big gain.
    Modern Muscle is a good source for VVT Hemi upgrades, but swapping a cam in is a big job and IMO one you would do before Whipple install.
    Then when swapping out a cam, you can run into other needed upgrades to get the most out of the cam install...so in this case I'd stick with the stock cam.
    Better gains with exhaust mods such as Long Tube headers, but those too can be a pain to install...at least they are in a LX, not sure on a D, but in a LX you might as well just pull the heads its that much a pain.
    Also, I've used a Fastman modded TB on a 4.7L with a cam swap and didn't see any real gain. I think it was a waste of coin.
    Problem is it was just a taper bore, the TB blade was the same size as OEM, its like putting a 3" on in place of the 2.5" exhaust but leaving the 2.5" muffler on.
    Bottom line is unless the TB blade is replaced with a larger diameter and the entire TB bored out you won't see any real gain.
    I like the Hellcat TB swap or Whipple TB swap much better than modifying the OEM TB.
    Bryali and DD2015RT like this.
  7. #6
    Durango Guru Robfrmny21's Avatar
    Feb 2015
    Bronx ny
    1,690
    8922
    503 times
    This guy I know who did a cam on his 2015 charger rt told me he paid 4500$ parts n labor n tune.
    1000 was for ecu n tuner. He went with a inertia Motorsports cam, car made 440whp and 415wtq from a 5.7 bottom.
    Safe to say our oem cam is deff a power robber
    2015 rt silver metallic blk top AKA BEAST MODE
    Afe momentum intake ,vled tritons, Ddm tuning can bus hid 3k fogs ,upr catch can, weather tech floor mats,Corsa cat back!! I post using my cell phone so please forgive misspellings and grammar errors .
  8. #7
    Jun 2016
    Texas
    164
    12928
    50 times
    15DDRT
    FYI. Talked to Modern Muscle and they confirmed a fit with the Whipple. Ordering one today.
    Bryali likes this.
    DD15-R/T-RWD
  9. #8
    Feb 2015
    Bronx ny
    1,690
    8922
    503 times
    Dude the hell cat tb are like 220-250 just buy the adapter 450 is really over priced
  10. #9
    Jun 2016
    Texas
    164
    12928
    50 times
    15DDRT
    Quote Originally Posted by Robfrmny21 View Post
    I definitely looked at that prior to making my purchase, and factoring in with them making sure it works on my Whipple. Figured with the port/polish and the experience of MM... it was a worthy investment.
    DD15-R/T-RWD
  11. #10
    Sep 2015
    46
    10822
    3 times
    DD2015RT. How much the custom grill cost you?
  1. Throttle body
    By theorvs in forum Durango Discussions
    Last Post: 12-29-2014, 07:37 PM
  2. What throttle body should I get
    By ppowell1983 in forum Durango Discussions 2014+
    Last Post: 11-02-2014, 05:24 PM
  3. Throttle body
    By 20durango03 in forum Durango Discussions 1998-03
    Last Post: 08-01-2011, 09:05 PM
  4. new throttle body!!
    By midnite in forum [General] Dumping Ground
    Last Post: 11-09-2008, 06:47 PM
  5. Throttle Body
    By Hoss in forum Durango Accessories 1998-03
    Last Post: 04-11-2005, 11:31 PM
