Tire pressure sensor light - Page 2
Page 2 of 2 FirstFirst 12
Results 11 to 12 of 12
Thread: Tire pressure sensor light
  1. #11
    Junior Member
    Dec 2016
    North Coast
    200
    21433
    61 times
    2014 Limited AWD V6 Premium, Safe/Conveniece & Tow packages, Opt7 LED fog lamps
    When I got a set of TPMS for my winter wheel/tire package last month on the my '14 Limited, I bought these and so far I have not have an issue.
    This is about the less expensive price I could find on these 433MHz Schrader #20398 units - they cost about $85 for a set of four (4) shipped.
    https://www.amazon.com/Schrader-2039.../dp/B004JBQ2JY
    My '14 Limited relearned these new sensors without any issues and without having to use the learning tool as I have to do with the wife's Buick.
  2. #12
    Super Moderator tomk's Avatar
    Jun 2004
    Amherst, MA
    11,030
    16
    1046 times
    Quote Originally Posted by 14maxr/t View Post
    Yes it does flash when the car is started and then solid. Is there a box that controls the sensors? Thanks
    You're going to need to pull the TPMS fault code(s) with a scanner.. I don't know if a generic OBD scanner can pull codes from the TPMS system..
    What?
    07 JGC Red Rock Limited 5.7L
    And some past Durangos
    de W1PF
  1. Power Steering Pressure Sensor P0551 - Code Won’t Clear - New Sensor
    By fcastro in forum Durango Discussions 1998-03
    Last Post: 04-06-2017, 12:29 PM
  2. Omega tire pressure sensor?
    By Murtur in forum Durango Accessories 2004-09
    Last Post: 10-23-2015, 05:10 AM
  3. 04 Hemi limited low tire pressure light
    By Hanne in forum Durango Discussions 2004-09
    Last Post: 12-07-2014, 02:00 PM
  4. Tire pressure low, light on
    By shels11 in forum Durango Discussions 2014+
    Last Post: 10-05-2014, 07:04 AM
