Aftermarket backup camera install questions
Page 1 of 4 123 ... LastLast
Results 1 to 10 of 32
Like Tree8Likes
Thread: Aftermarket backup camera install questions
    May 2015
    3
    9886
    Bought a '14 SXT with everything I wanted except the backup camera (do have the 8.4 w/out nav.) Figured I'd put it on aftermarket. One dealer said they'd do it for $800-ish using NavTV and a similar quote using a Pac interface. Seems high (but maybe not)
    So, after lurking aplenty in here (I've searched much, so if I missed something, apologies) and various websites, I'm wondering if anyone can confirm/deny the claims below:
    1) No matter what aftermarket video unit is bought (like the Crux/Pac/Mopar 82213322/etc..), the 8.4/engine computer/whatever must go into Dodge for 'reprogramming' for 1/2 hour of labor.
    2) There should be a power wire (or even a harness) back in the hatch door of any D for the backup camera.
    3) The wireless video transmitters sold on Amazon/ebay DO work, work well, and do not need to be out in plain sight in the cabin.
    4) There is no direct connection from the back of the 8.4 to a backup camera.
    Any knowledge/guidance about this is highly appreciated.
    May 2015
    Hampton, VA
    55
    9680
    17 times
    2014 Dodge Durango SXT
    If you get the crux camera interface it comes with a harness that goes directly into the radio and the factory harness plugs into the crux harness. I can take pics tomorrow if you want to see. I installed the crux interface camera on my 14 SXT and did not have to make a trip to the dealer, as soon as it was plugged in it worked. I even started with the 5.0 screen and upgraded to the 8.4an and it's worked on both head units. Let me know if you have any other questions
    AmStatic likes this.
    May 2015
    3
    9886
    Many thanks for the info, Jack; pics would be great if you have the time.
    When you installed the camera - did you have to run the wire all the way back and was there any sort of harness once you got there?
    May 2015
    Hampton, VA
    55
    9680
    17 times
    Here are the pics with some sort of step by step. First you have to remove the trim panels and all wires were run from the rear to the front on the drivers side so connections could be made under the drivers seat. Aftermarket backup camera install questions-img_2251.jpgAftermarket backup camera install questions-img_2252.jpgAftermarket backup camera install questions-img_2253.jpgAftermarket backup camera install questions-img_2255.jpgAftermarket backup camera install questions-img_2260.jpgAftermarket backup camera install questions-img_2262.jpgAftermarket backup camera install questions-img_2263.jpgAftermarket backup camera install questions-img_2265.jpgAftermarket backup camera install questions-img_2267.jpgAftermarket backup camera install questions-img_2268.jpg
    May 2015
    Hampton, VA
    55
    9680
    17 times
    Here are the rest of the pics. Let me know if you have any questions. Aftermarket backup camera install questions-img_2269.jpgAftermarket backup camera install questions-img_2270.jpgAftermarket backup camera install questions-img_2272.jpgAftermarket backup camera install questions-img_2275.jpg
    It was pretty much plug and play. The instructions given with the camera were not that great and took about 2 hours total with having to figure out which way to run the wires. Also broke the bottom pillar panel on drivers side, new one on order to replace. Hope this helps out.
  7. #6
    Durango Expert AmStatic's Avatar
    Sep 2014
    Fort Lauderdale, Fl
    638
    7248
    350 times
    Dodge splash guards, 3" black nerf bars, Mopar hood deflector, Debadged, hashmarks, BT Catch Can
    yes! Thank you! I'm seriously considering this!
    Can I ask what it costs?
    *front tint * MOPAR Hood Deflector * MOPAR Splash Guards * 3" Black Nerf Bars *
    * debadged * matte black fender "gills" * Billet Tech Catch Can
  8. #7
    May 2015
    Hampton, VA
    55
    9680
    17 times
    The camera kit cost me a little over 500 from crutchfield. I had it on my titan and was disappointed when the durango didn't have it. I also started with the connect 5.0 and upgraded to the 8.4an.
  9. #8
    Apr 2015
    8
    9571
    1 times
    2015 Durango SXT Ralley
    Looks good jack0910. I look forward to installing it.
  10. #9
    Durango Guru Citadel Brian's Avatar
    Jan 2014
    New Jersey
    1,406
    3771
    334 times
    This might be nice as a sticky!
    2014 White Citadel 5.7 loaded except for DVD
    2007 Jeep Grand Cherokee 5.7 Limited QDII
    1968 Pontiac Firebird 350 4spd #'s matching
    2003 HO Cummins Ram 6spd QCSB sold.
  11. #10
    May 2015
    Hampton, VA
    55
    9680
    17 times
    No problem VTOLdriver, did you have any other questions? Citadel Brian, what did you mean as a sticky?
  1. 2015 Durango backup camera
    By JimG in forum Durango Discussions 2014+
    Last Post: 10-30-2016, 05:15 PM
  2. Backup Camera Show Black Screen!!!
    By 115080069 in forum Durango Discussions 2014+
    Last Post: 04-27-2015, 01:27 PM
  3. Jerky backup camera?
    By klasango in forum Durango Discussions 2014+
    Last Post: 07-26-2014, 06:21 PM
  4. UConnect Backup Camera 'shadow' lines...
    By elcid2000 in forum Durango Electronics 2011 +
    Last Post: 02-07-2014, 04:48 PM
  5. Backup camera is in
    By rayjj in forum Durango Discussions 1998-03
    Last Post: 08-03-2006, 07:20 PM
Search tags for this page
2014 dodge durango backup camera
2014 durango backup camera install
install backup camera dodge durango
pac bci ch41 durango
pac bci-ch41 install
