blue smoke at startup/oil usage star case s1418000028
Page 1 of 2 12 LastLast
Results 1 to 10 of 20
Like Tree4Likes
Thread: blue smoke at startup/oil usage star case s1418000028
    Grasshopper goodB0Y's Avatar
    Oct 2014
    Vancouver Canada
    43
    7567
    5 times
    2014 Durango RT
    just got my d back from the dealer...
    I've been experiencing blue smoke at start up along with an oil usage problem (2 liters in 3500km)
    well apparently there is a star case #s1418000028 that relates to my problem.
    here's from my invoice:
    cause:
    Burning oil
    correction:
    remove intake manifold to pressure test PCV passage as per star case s1418000028. PCV passage leaks. Intake manifold requires replacement. re-install intake. Parts on order.
    there is another line on my invoice that has my complaint about blue smoke... it just says to see above.
    now... i'm trying to understand how the PCV passage leaking would add oil to the intake? the PCV is supposed to exit into the intake... idk...
    wondering if anyone here has ever had there intake manifold off and could share some insight...
    or maybe the leak is in a spot where there is allot of oil spray and it picks up more oil...
    anyone have any thoughts?
    claudio.anveres likes this.
    May 2004
    ICE COLD NORTH JOISEY
    28,020
    7
    1775 times
    2013 R/T D HEMI
    The passage is supposed to be a specific path the recirculating oil fumes travel into, if that is compromised oil fumes and oil (with no catch can) will go right down in main intake and into cylinders burning the oil
    Oct 2014
    Vancouver Canada
    43
    7567
    5 times
    2014 Durango RT
    Add to that you would think that it would cause a lean condition... Unless it's before the pcv valve (valve is located on/in the intake manifold)
    Oct 2014
    Vancouver Canada
    43
    7567
    5 times
    2014 Durango RT
    Edit:
    The more I think about it I guess the leak is either before or after the pcv valve into the crank case...
    Man I hope this is the fix...
    Edit:
    Looks like there is a hose coming off the valve ( thought it might be integral) means the leak has to be before the valve
    Senior Member
    Oct 2007
    Staten Island NY
    379
    1610
    74 times
    1998 D, base SLT, '14 R/T Black Crystal
    I have issue with this DX. If there's any intake leak at all, PCV or otherwise, there will be fuel trim compensation. This SHOULD cause a MIL.
    '14 Durango R/T, Black Crystal. Midnight
    '98 Durango 5.2, Chilipepper red. Big Red
    '04 Cummins Ram 3500 6 speed (TDR member) The Blue Buggy
    '71 340 Duster bracket car, under transformation back to street duty- The car I drove to high school.
  7. #6
    Oct 2014
    Vancouver Canada
    43
    7567
    5 times
    2014 Durango RT
    What do you mean by a mill ?
  8. #7
    Jun 2014
    91
    5711
    13 times
    MIL= Malfunction Indicator Lamp (check engine light), I completely disagree with Wayne in his assumption that the car would throw a check engine light in this situation, i see leaking intake manifolds all the time with no check engine light at all, the fact is the computer can compensate and has a threshold to where its going to trigger the lamp and set a code. a small leak may only require the fuel adaptations to need to be slightly adjusted to compensate to the point where that threshold has not been exceeded. I think this diagnosis is 100% plausible as a cause of oil consumption and not triggering the check engine light as the condition is most prevalent at startup where the vehicle is in a rich running condition and is in open loop not actively monitoring fuel trim information via the O2 sensors. I could go on and on about this.... But i say this is a valid attempt the dealer is making to address your situation. Oil consumption issues are not clear cut easy to fix issues and be glad they came up with something that at least makes sense to try and remedy your issue.
  9. #8
    Oct 2014
    Vancouver Canada
    43
    7567
    5 times
    2014 Durango RT
    I agree with you ... If the leak was small enough there is a very good chance it wouldn't set the check engine light... And I am very pleased that we have something to try...
    If the passage is of any length longer than a couple of inches then there is also a good chance it will collect oil... Putting that oil directly into the manifold
  10. #9
    Super Moderator tomk's Avatar
    Jun 2004
    Amherst, MA
    10,863
    16
    992 times
    it doesn't take much of a leak to get a puddle of oil in the intake manifold..
    I suspect an air leak into the intake manifold won't cause a fuel trim MIL under most conditions.. it would be more likely to trip an idle control MIL.
    Good info about the passage leak, though.. that is a diagnosis we have not seen, and might explain why the TSB doesn't cure all instances of blue smoke..
    ...tom
    Be amazed at the friends
    You have here on your trip
    07 JGC Red Rock Limited 5.7L
    And some past Durangos
    de W1PF
  11. #10
    Senior Member
    May 2014
    NJ
    294
    5340
    113 times
    14' R/T
    InTune, AFE, Corsa.
    Quote Originally Posted by FSTDANGO3 View Post
    So if I have a catch can and still see oil on cold start on level ground what should I do? I didn't see the blue smoke until I put the Corsa on which I know didnt affect it but makes it visible due to the more free flow. I have 5k miles and want to go for my first oil change soon. My catch can has been 50% full the past 1k miles and I just emptied it so I know the drainage is working from the way I routed the lines to and from the BT can. No puddling effect going on there.
  1. Blue smoke from exhaust
    By Jeepstare in forum Durango Performance 2011+
    Last Post: 04-28-2016, 04:25 AM
  2. Do Catch Cans Prevent Blue Smoke At Start Up?
    By frank bullitt in forum Durango Performance 2011+
    Last Post: 11-17-2014, 04:00 PM
  3. Blue smoke on startup - 2014 Durango R/T
    By shortydurango in forum Durango Discussions 2014+
    Last Post: 11-17-2014, 03:58 PM
  4. Oil Usage
    By WhiteD in forum Durango Discussions 1998-03
    Last Post: 03-07-2010, 09:05 PM
  5. Octane usage
    By RobDA in forum [General] Dumping Ground
    Last Post: 08-14-2007, 04:14 PM
Search tags for this page
2011 durango oil consumption with hemi
2014 durango oil consumption
what can stop my hemi from startup smoke
