Moisture inside the headlights
Page 1 of 5 123 ... LastLast
Results 1 to 10 of 43
Like Tree3Likes
Thread: Moisture inside the headlights
    Junior Member Lobstah Slayah's Avatar
    Feb 2014
    South Florida
    165
    3879
    27 times
    2014 Durango R/T
    I'm not sure if this is normal or if it is a result water condensation on a hot area. I first noticed it after driving home and having a rainstorm hit. As I got out I noticed the cloudiness of moisture. The second time was yesterday. i drove home had dinner then went outside to wash the lovebugs off my car. Bam! More moisture. Both times the lights were warm from use and both times they got fogged up. Later it was gone. I guess it could be normal condensation like on a cold glass on a hot day but shouldn't a headlight be a sealed unit that has no moisture inside? Anyone else having this issue?
    2014 Durango R/T
    Premium Nappa leather group | Captain's Chairs w/second row console | Uconnect 8.4 AN | Trailer Tow Group
    Durango Guru FINELINETOYS's Avatar
    Mar 2014
    Waterloo iowa
    1,263
    4268
    326 times
    I have had that too a few times.it clears itself up and I can't see any actual drops of water ,only a fog. Mine did it when it was being washed.it hasn't happened for a while.I mentioned it to Dodge and they didn't seem concerned. I keep an eye on it. It might be our HIGH HUMIDITY locations where we are at.
    Super Moderator boomer775's Avatar
    Feb 2014
    Long Island, NY
    2,244
    4090
    902 times
    2015 Citadel
    None worth mentioning
    Quote Originally Posted by Lobstah Slayah View Post
    Had the same issue with mine when I 1st got it, but it went away after time. Dealer said it primarily had to do with the amt of heat that the HIDs produced - it happens on a lot of their cars apparently (300Cs particularly) if you do some google searches on it.
    Current:
    2015 Durango Citadel
    2017 Daytona 392 Charger
    Gone, but not forgotten:
    2014 Durango R/T
    K&N CAI I 22" Viper Reps I MGP Caliper Covers I Corsa Exhaust I Diablotoona Tune I Modern Muscle TB I 180 TStat
    BT Catch Can I Lots of Billet Goodies I Tinted Tailights I Mopar Hitch I Mopar Stainless Pedals & Sill Guards I Triton LEDs I DDM 3000K HID Fogs I Husky Splash Guards
    Check out my noob's guide to gen 3 modding: http://www.dodgedurango.net/forums/d...3-durango.html
    dodgedurango.net - Often Imitated, Never Duplicated
    Durango Jedi ppowell1983's Avatar
    Apr 2014
    Plainfield, IL
    2,760
    4973
    862 times
    2014 Dodge Durango R/T Red
    I had this in a few different vehicles that had this and the assemblies were replaced under warranty, I can't stand when there is moisture in the light assembly.
    Grasshopper Stealth R/T's Avatar
    Mar 2014
    Illinois
    53
    4631
    11 times
    2014 Durango R/T
    K&N Intake, Tint, HID Fogs, R/T Fender Hash, De-badged, 22" XO Monaco's, CF Caliper Covers
    I also have encountered this, but on the driver's side only. 3k miles so far, so I will definitely bring it to the dealer for a look. I am concerned that it will eventually have water sitting in the bottom of the unit.
  7. #6
    Sep 2004
    Anaheim, ca
    5,598
    77
    163 times
    Sounds like the factory seal between clear plastic and the rear housing is not good...
    2015 Dart Aero turbo1.4t, GFB DV+ BOV
  8. #7
    Durango Guru that_guy's Avatar
    Nov 2011
    Pittsburgh, PA or Columbia, SC
    1,820
    2063
    178 times
    '99 Durango, '69 Satellite , '14 Charger R/T
    Too much to fit in this box
    Let it dry out and check the seals on the caps or whatever on the lights. If it keeps getting moisture inside have the dealer replace it. Moisture can degrade the reflective surface in the projectors and it isn't exactly good for bulbs either.
    -Matt
    Intense Blue '99 Durango SLT 5.2L V8 FT4X4
    Ivy Green '69 Plymouth Satellite 318
    Pitch Black '14 Charger R/T Awd
    Picture/Mod Conglomeration Thread
    Why not to put pnp HIDs in halogen reflectors
  9. #8
    Feb 2014
    Long Island, NY
    2,244
    4090
    902 times
    2015 Citadel
    Quote Originally Posted by dizzyD View Post
    Curious about this - the Service guy mentioned that the lenses vented to let heat out - don't know if that is only on those with HIDs or all 2014 Ds. Then again, he could have just been feeding me a heaping pile of horsesh*t
    Current:
    2014 Durango R/T
  10. #9
    Nov 2011
    1,820
    2063
    178 times
    There usually are some sorts of vents in headlights, but they're meant to keep moisture out. The problem with projectors is that the heat is concentrated in one place, which creates differential temperatures in the light, which can create condensation.
    -Matt
  11. #10
    Dec 2013
    WI
    65
    3444
    11 times
    2014 Grand Cherokee Summitt
    Front tint, catch can, whipple supercharger ordered
    just returned from the dealer today - had the tranny TSB done. They washed my car, then I noticed the fog/moisture - not a happy camper. I turned about and approached my dealership contact. He pulled up a tsb online stating that dodge recognizes the problem. They will only do repair work on it, if it's actually beeding up with water droplets - IE not just fog alone. They also state that if the fog disappears after 20mins, then it's OK, no need to do anything. They also referenced their is venting to let heat out. Not sure myself. ALso, not very happy about condensation building up in there. I suppose I will watch it too - however there is a TSB on it and consumers have 'bitched' about it.....
  1. License Plate LED out due to moisture on 14 R/T. Has anyone had this too?
    By ThatGuyFromOhio in forum Durango Discussions 2014+
    Last Post: 02-28-2016, 02:35 AM
  2. Moisture in passenger side 2 piece headlight
    By Thebugman in forum Durango Discussions 1998-03
    Last Post: 11-25-2007, 07:53 PM
  3. moisture getting in 1pc headlights?
    By greendurango in forum Durango Accessories 1998-03
    Last Post: 11-07-2007, 05:08 AM
  4. Moisture in the headlight
    By prk2001 in forum Durango Discussions 1998-03
    Last Post: 02-21-2006, 09:13 PM
  5. Headlight Moisture
    By Mexican Durango in forum Durango Discussions 1998-03
    Last Post: 11-22-2004, 05:09 AM
Search tags for this page
2011 dodge journey headlight condensation
2015 durango headlight moisture
condensation in dakota headlights
condensation in headlight a durango
moisture in headlight on 2014 dodge durango
