Front turn signal LED conversion - Page 2
Page 2 of 13 FirstFirst 123412 ... LastLast
Results 11 to 20 of 130
Like Tree23Likes
Thread: Front turn signal LED conversion
  1. #11
    Feb 2014
    44
    3989
    3 times
    i used the canbus bulbs from autolumination.com ... their amber is close to red. will post a video once the weather clears up, been raining the past 2 days.
  2. #12
    TLS
    TLS is offline
    Jun 2014
    2
    5779
    4 times
    Here is a short video after I swapped the passenger side front turn signal with a Triton LED kit and left the drivers side stock. As you can see, the output is almost identical but the LED "flash effect" is much more obvious when both lamps are activated and flashing.
    The install on the passenger side was very straightforward while the drivers side requires you to remove the entire air box to access the turn signal socket and wiring. The Triton kit requires NO cutting or splicing into the factory wiring at all and includes the control boxes (resistors) to eliminate any "fast flash" bulb out warnings.
    My next project on this 2014 DD is a kit to stop the DRL's from extinguishing when a turn signal is activated. I just don't like the look of it and I am not convinced it is truly a safety feature. The turn signals can easily be seen by other motorists with the DRL activated.
    crankish and SSonnentag like this.
  3. #13
    Super Moderator boomer775's Avatar
    Feb 2014
    Long Island, NY
    2,158
    4090
    863 times
    2014 R/T & 2015 Citadel
    Enough to cause a divorce
    That looks great. Thanks for the video!
    2014 Durango R/T
    K&N CAI I 22" Viper Reps I MGP Caliper Covers I Corsa Exhaust I Diablotoona Tune I Modern Muscle TB I 180 TStat
    BT Catch Can I Lots of Billet Goodies I Tinted Tailights I Mopar Hitch I Mopar Stainless Pedals & Sill Guards I Triton LEDs I DDM 3000K HID Fogs I Husky Splash Guards
    Check out my noob's guide to gen 3 modding: http://www.dodgedurango.net/forums/d...3-durango.html
    dodgedurango.net - Often Imitated, Never Duplicated
  5. #14
    Durango Guru FINELINETOYS's Avatar
    Mar 2014
    Waterloo iowa
    1,263
    4268
    326 times
    Keep us updated on DRL kit. I would like to do that as well. What kit are you referring to to accomplish this? LOOKS REALLY GOOD!!!
  6. #15
    Senior Member fbonifacio's Avatar
    Jan 2014
    East Bay, Ca
    310
    3841
    53 times
    2014 Dodge Durango RT AWD
    MGP CF Calip Covers | 6K Head & Fog Lights | Int Cree LED | Tints | Res Delete w/ 4" Blk Ex Tips
    You guys are such a bad influences LOL! I'm tempted to do this as well
    Might go the cheaper route tho, but also with vleds.
    Wonder if this will work and not get any error fast flash... http://www.vleds.com/shop-bulb-numbe...157-amber.html
    2014 Durango RT AWD
    Granite Crystal Metallic | Technology Group | Trailer Tow Group IV | Capt Chairs | Nappa |Sunroof | DVD & Nav
  7. #16
    Durango Guru that_guy's Avatar
    Nov 2011
    Pittsburgh, PA or Columbia, SC
    1,816
    2063
    178 times
    '99 Durango, '69 Satellite , '14 Charger R/T
    Too much to fit in this box
    The tritons are one of the few drop in led bulbs that work better than the incandescent bulbs in terms of brightness. They're very expensive though. It's hit or miss with other leds, you just have to make sure they're bright enough. Most of them are so dim you'd be better off sticking a candle in your turn signal.
    fbonifacio likes this.
    -Matt
    Intense Blue '99 Durango SLT 5.2L V8 FT4X4
    Ivy Green '69 Plymouth Satellite 318
    Pitch Black '14 Charger R/T Awd
    Picture/Mod Conglomeration Thread
    Why not to put pnp HIDs in halogen reflectors
  8. #17
    Junior Member BigJon's Avatar
    Dec 2013
    139
    3272
    37 times
    2013 RT/AWD 5.7 HEMI Durango
    K&N,Borla,Trinity,Halo's,BullBar &Nerf Bars are Linex,windows&windshield tinted,Brembo/JGC wheels
    I used 3157 switch backs in mine. Had to add a resistor to each bulb and cut and trim the socket to fit. But well damn worth it for one of a kind lights in our trucks. They switch from the 8k color LED to a amber for the turn signal.
    Attached Thumbnails Attached Thumbnails Front turn signal LED conversion-image.jpg   Front turn signal LED conversion-image.jpg
  9. #18
    Senior Member crankish's Avatar
    Jan 2014
    AZ
    352
    3779
    94 times
    2014 Durango R/T
    22x10.5" rims, Borla catback, K&N, LED turns/interior, BREMBOS, black grill, fender stripes
    Quote Originally Posted by BigJon View Post
    So are they always lit in 8K then switches to blinking amber when turned on?
    BigJon and MotorMolarDoc like this.
    Stance is everything
  10. #19
    May 2014
    Southeastern Wisconsin
    58
    5378
    8 times
    2014 Dodge Durango R/T
    Alright guys I bought these
    http://www.amazon.com/gp/product/B00...?ie=UTF8&psc=1
    They work great put in one at a time and trying them out they blinked fast for about 5 seconds and then the car synchronize all the lights and they work perfectly and man are they bright. If you put them in and they don't work reverse the polarity and they will fire up. I love them look great and they are cheap.
    Sent from my Nexus 7 using Tapatalk
    2014 Durango R/T, AWD, Tech Pack, Tow Pack - Black - Painted Calipers/Rotors - HID Fog Lights - LED Front Turn Signals - Tinted Front Windows 35%
  11. #20
    Senior Member
    Apr 2014
    332
    5087
    30 times
    2014 Durango Limited AWD
    Quote Originally Posted by supertech30 View Post
    Amazon.com: 3157 Amber Samsung High Power Led Turn Signal Corner/tail Light Bulbs/bulb: Automotive
    Somehow I have doubts based on the reviews. Can you take a picture comparing the two?
  1. Turn Signal Issue
    Last Post: 08-14-2011, 12:32 AM
  2. Driver Turn Signal
    Last Post: 07-13-2010, 05:01 PM
  3. Right Turn Signal
    By Machine in forum Durango Discussions 1998-03
    Last Post: 07-19-2008, 11:24 PM
  4. Right Front Turn Signal Socket part #??
    By BLK2KD in forum Durango Discussions 1998-03
    Last Post: 05-22-2008, 05:49 PM
  5. Right Turn Signal Stays ON
    By Djaizspecial in forum Durango Discussions 1998-03
    Last Post: 02-09-2006, 12:32 PM
Search tags for this page
2014 dodge durango front turn signal socket
2014 dodge durango turn signal bulb
2014 durango led turn signals
dodge led signal conversions
turn signal
