Front turn signal LED conversion - Page 12
Page 12 of 14 FirstFirst ... 21011121314 LastLast
Results 111 to 120 of 133
Like Tree24Likes
Thread: Front turn signal LED conversion
  1. #111
    Durango Guru caskey_b's Avatar
    Aug 2014
    Oxford, IA
    1,759
    6809
    458 times
    2011 Crew / 2014 Limited
    HIDs, Mopar Hitch/wiring, Mopar splash guards, Heated leather conversion in 2011 Crew
    And no resistor needed?
    -Brian
    '11 Crew AWD 3.6L
    Spectre intake
    OPT7 HIDs
    OPT7 CREE V2 fogs (wired as DRL)
    Mopar steps
    Mopar hitch/wiring
    Mopar mud guards
    WeatherTech mats
    Mopar door sill guards
    OPT7 FluxBeam DRLs
    Cloth to Leather Conversion
    '14 Limited 2WD 3.6L
    AFE Intake
    Opt7 LEDs
    Opt7 HID 3000k fogs
    Go Rhino steps
    Clean Cut Decals door sill guards
    Mopar hitch/wiring
    Mopar mud guards
    Husky mats
    Luverne 3" bull bar
    255/75R17 Wranglers
    Vvivid vinyl interior trim
    Custom license plate LED mod
  2. #112
    Durango Expert Pappy35's Avatar
    Jun 2015
    West Tennessee
    571
    10084
    133 times
    '17 Durango Citadel
    One of the questions in the Amazon ad asked about needing a resistor and the seller responded at yes, one needed to be added. That's not Durango-specific but buyer beware...
    '17 Durango Citadel, White Knuckle, Tech, and Tow
  3. #113
    Durango Guru rayjj's Avatar
    Dec 2005
    1,786
    934
    22 times
    No resistor added. Now I dont know if that will work for all years/models, but for me no issues as all. Simple bulb swap.
    Tweak likes this.
  5. #114
    Apr 2016
    Washington State
    24
    12448
    14 times
    2016 Dodge Durango SXT Blacktop
    Installed LED turn signals today. I got the bulbs from Automotive Lighting & Accessories: HID Kits | LEDs | Audio/Video. After reading the forum and comparing all the different types I figured I would give these a shot from a local Seattle company. I went with the "3157 3057 4157 – 30W CREE LED Bulb" for $29.99. They also have an 80w for $39.99 but I compared the lumins between 30w and 80w, the 30w is slightly brighter than stock. They are plug and play out of the box. No errors/alerts/rapid flashing or any resistors needed, just the led bulb.
    Install was simple. I did have to loosen the coolant reservoir on the pax side cause my man hands couldn't quite squeeze behind it. Driver side was simple cause the K&N is much easier to get behind than the stock air filter.
    Left (pax) side is the new LED, right (driver) side is stock bulb.
    Tweak, Splyce, davewg and 1 others like this.
    - Will
    2016 SXT 2WD 3.6L
    Blacktop package - K&N Intake - LED interior lights - LED turn signals - Tinted Taillights - Husky X-act Contour liners - Husky mud guards
  6. #115
    Jun 2016
    Long Island New York
    21
    12867
    5 times
    2014 Citadel
    Looks great, going to check them out!
    2014 Citadel, 5k Fogs, 20% tints factory match fronts, Weathertech mats all around, Weathertech rain guards.
  7. #116
    Grasshopper Ryno15's Avatar
    Jul 2015
    NJ
    65
    10399
    44 times
    2017 R/T
    AFE Intake, Philips 6000k LED Fogs, Gorilla Lugs, Magnaflow, MGP Calipers
    Did you also do your backup lights? Looks good. I want to do signals and backups.
  8. #117
    Apr 2016
    Washington State
    24
    12448
    14 times
    Quote Originally Posted by Ryno15 View Post
    Thanks! Backup LED and HID fog/headlights are all on the to-do list. Nothing ordered yet.
    - Will
    2016 SXT 2WD 3.6L
  9. #118
    Dec 2005
    1,786
    934
    22 times
    Quote Originally Posted by Willcnfo View Post
    Installed LED turn signals today. I got the bulbs from Automotive Lighting & Accessories: HID Kits | LEDs | Audio/Video. After reading the forum and comparing all the different types I figured I would give these a shot from a local Seattle company. I went with the "3157 3057 4157 — 30W CREE LED Bulb" for $29.99. They also have an 80w for $39.99 but I compared the lumins between 30w and 80w, the 30w is slightly brighter than stock. They are plug and play out of the box. No errors/alerts/rapid flashing or any resistors needed, just the led bulb.
    Funny how different the coolant tank is on the 3.6 vs the 5.7. Was nothing to move on mine to get to the passenger bulb.
  10. #119
    Jul 2015
    NJ
    65
    10399
    44 times
    2017 R/T
    Funny how things work...this morning I got a front right signal out message...went and ordered the same bulbs you installed. Thanks again for the info.
  11. #120
    Senior Member
    Sep 2004
    455
    72
    58 times
    Tried installing LED switchbacks on my SXT+....the new LED lit up white with parking lights on (like it should) and blinked at the normal speed with the turn signal. However, the inside turn indicator hyper-blinked, and I had a bulb out warning/chime.
    For those of us to have to use a resistor to cancel the bulb out/hyper-blink issue, where and how did you mount the resistors?
    After poking around under my hood, it seems the best place would be the steel radiator support/frame cross bar just under the hood behind the radiator. There are some holes already stamped in the bar, if I can find a self tapping sheet metal screw of the proper size. The holes are slightly larger than 1/4" and smaller than 5/16", tested with drill bits to try to gauge size.
    Thoughts?
    2015 SXT Plus, Billet silver
  1. Turn Signal Issue
    Last Post: 08-14-2011, 12:32 AM
  2. Driver Turn Signal
    Last Post: 07-13-2010, 05:01 PM
  3. Right Turn Signal
    By Machine in forum Durango Discussions 1998-03
    Last Post: 07-19-2008, 11:24 PM
  4. Right Front Turn Signal Socket part #??
    By BLK2KD in forum Durango Discussions 1998-03
    Last Post: 05-22-2008, 05:49 PM
  5. Right Turn Signal Stays ON
    By Djaizspecial in forum Durango Discussions 1998-03
    Last Post: 02-09-2006, 12:32 PM
Search tags for this page
2014 dodge durango front turn signal socket
2014 dodge durango turn signal bulb
2014 durango led turn signals
dodge led signal conversions
remove orange insert from headlight 2014 durango
