Rear heater core
Results 1 to 4 of 4
Thread: Rear heater core
    Dec 2016
    4
    21674
    Rear heater core
    04 dodge durango 5.7 4wd how hard is it to replace the rear heater core? It blows cold in the rear and when the heat is on in the rear I'm losing water. I am assuming that is the problem. Advice?
    Durango Guru Don Fox's Avatar
    Sep 2004
    Oxford, Ohio
    1,139
    100
    36 times
    TB:
    Are you losing water or coolant? There is also an AC evap back there. More likely, your issue is that the plastic flapper door that directs the air between AC and heat has broken.
    IIRC, you will have to remove that side of the interior which is doable, but not very fun.
    2004 Durango SLT Hemi AWD "The Flame Red Rocket." A transplant from Cleveland, Ohio on 3/26/10.
    2014 Billet Silver Dodge Charger R/T Hemi AWD (10/26/16)
    2011 Mineral Gray Hyundai Santa Fe GLS AWD V6 (hers) (8/21/14)
    Dec 2016
    4
    21674
    I am losing coolant when the rear heat is on but not when I use the front only
  4. #4
    Sep 2004
    Oxford, Ohio
    1,139
    100
    36 times
    As a stop gap measure, you can bypass the core by gently removing the two connections at the base of the core under the rear quarter panel, and using some tubing/ pipe to close it up.
    Once that is done, you could also pressure test the core in place, and see if it holds pressure.
    Do you use the rear enough to warrant a repair, or might the bypass do you for now?
  1. Heater core
    By jrinaman in forum Durango Discussions 1998-03
    Last Post: 10-13-2012, 06:11 PM
  2. Heater Core
    By snowskull in forum Durango Discussions 1998-03
    Last Post: 10-05-2011, 11:49 PM
  3. 99D heater hose to heater core question
    By greendurango in forum Durango Discussions 1998-03
    Last Post: 05-05-2011, 07:44 PM
  4. Heater Core
    By black beauty in forum Durango Discussions 1998-03
    Last Post: 01-25-2010, 04:06 AM
  5. Heater Core, etc.
    By triola in forum Durango Discussions 1998-03
    Last Post: 12-05-2006, 08:30 PM
