Spark Plugs on 2008 5.7L Hemi?
Page 1 of 2 12 LastLast
Results 1 to 10 of 20
Thread: Spark Plugs on 2008 5.7L Hemi?
    Oct 2012
    19
    2128
    I just bought a 2008 Aspen with the Hemi and it has 34,000 miles on it with spark plugs that have never been changed. So I went to Autozone and bought 16 of the recommended Champion spark plugs (good enough for what I'm going to use them for), but how do you change them? Does someone have a clip from the service manual that shows where they are, how to change them, torque specs, proper gap, etc., etc? How many have needed to change them at 30,000 miles?
    Any advise would be appreciated. Thanks!
    Durango Guru Don Fox's Avatar
    Sep 2004
    Oxford, Ohio
    1,165
    100
    38 times
    As you've read, the factory spec is change at 30K and the gap is .045. The plugs in my Hemi are less than 1K from 40K and still doing well. At a whopping $2 a plug, when the time comes I plan to change them all. Some folks feel since the secondary plug only fires on the opposite side of the engine during that cylinders exhaust stroke, they can last longer. I say when you go in, do em all!
    There are 8 plugs in each head with coil packs mounted over 4 of the 8 on each side secured by 10mm bolts if memory serves correctly. Dealers are rumored to charge $250-$300 for spark plug replacement on the Hemi as it does take 2-3 hours. You'll want to have a good selection of extensions and it'll help to remove the air hat and associated tubing to the air box to give you room to work.
    Super Moderator tomk's Avatar
    Jun 2004
    Amherst, MA
    10,672
    16
    930 times
    I think by '08 the Durango/Aspen had gone to the dual coil-on-plug setup like my '07 JGC has. I don't know the Gen-2 under hood all that well so I'll defer to Don as far as what has to (or should be) removed.
    Anyway, if it's dual coil-on-plug, there'll be a pair of 10mm head bolts to remove for each coil and then carefully but firmly wiggle the boots out and blow out any dirt from the spark-plug tubes. The plugs are tapered-seat in an aluminum head, so you have to be reasonable careful when torquing them down during installation. You should also apply some dielectric grease to the insides of the ends of the boots before re-installing them.
    Be amazed at the friends
    You have here on your trip
    07 JGC Red Rock Limited 5.7L
    And some past Durangos
    de W1PF
    Jul 2007
    Real close to Muffler Man
    4,321
    1532
    585 times
    2007 Durango Night Runner
    1 of 241 made
    There's very little room under the hood to get to them and it looks like a real PITA. Don, is it the same with the 07?
    2007 HEMI Nightrunner D
    2015 Grand Caravan R/T
    1996 Ford E-350
    Sep 2004
    Oxford, Ohio
    1,165
    100
    38 times
    Haven't been under the hood of an 07 so I can't speak to that, but the coils in my 04 are attached to the valve cover with two 10mm bolts.
    The are 2 plugs under each coil. I now believe that both plugs are fired for a given cylinder on the power stroke, and additionally a plug on an opposite cylinder is fired on the exhaust stroke for emissions purposes.
    My Hemi plug change at 50K is documented on this forum. Eventually, the electrodes will wear away to the point that the engine wont run.
    I do not recommend this. I noted a very small increase in performance after the change, but overall it ran fine beforehand.
  7. #6
    Sep 2004
    Anaheim, ca
    5,529
    77
    149 times
    Time for some Taylor shorties. I love not having "extra long" plug wires going to the opposite side!
    2015 Dart Aero turbo1.4t, GFB DV+ BOV
  8. #7
    Oct 2012
    19
    2128
    Hey guys, sorry to rebirth this thread... but I still haven't installed the plugs And I don't really want to. A buddy of mine at work has an 08 Aspen as well. His has 120,000 miles, still on the original plugs! His MDS actually works better than mine! (and we both had the most recent MDS computer flash done at the dealership). And he gets really good overall gas mileage too.
    Is he lucky and skating on thin ice? Or is this pretty typical? I have never heard of replacing spark plugs before 100,000 miles before, so I'm struggling to drag out my chest of sockets and extensions, only to realize I don't have the correct ones, have to go out and buy 5 or 6 more different extensions, try them only to find out they don't work either, go back out to buy more, etc etc... This is the kind of luck I have. Only to have me break something and have to get the f'ing car towed to the dealership anyway!!
    Any thoughts would be much appreciated. Thanks!
  9. #8
    Jun 2004
    Amherst, MA
    10,672
    16
    930 times
    Quote Originally Posted by all_bran View Post
    You must be a young whippersnapper!
    I only know the dual-coil-on-plug setup, that is not all that bad. You'll need a good spark-plug socket, and some good tight-fitting extensions so that you can get that spark-plug socket out out of the tube when you're done. Air (canned or compressor) to blow any crap out of the tube before you pull the plug. Inch-pound torque wrench is a good idea if you aren't used to tapered seats in aluminum heads.
    The Durango engine compartment is somewhat tighter than the '07 GC engine compartment, so that might require more patience.
    ...tom
    de W1PF
  10. #9
    Oct 2012
    19
    2128
    Quote Originally Posted by tomk View Post
    ...tom
    Thank you for the insight... but that wasn't exactly what I was asking. I understand the manual says to replace them at 30k. But I currently have 47k on my hemi aspen and a buddy of mine has over 100k... seemingly with no ill-effect. But I don't know what I don't know... Will something magically come back to life that I forgot about if I replace the plugs? Or is this one of those things where you only need to replace the plugs only if you're towing a tractor trailer offroad at temperatures below 0 deg F or above 120 deg F? I'm struggling to find the justification to replace them if I have seen no ill-effect and someone with 120k on their hemi hasn't seen any ill effect either?
    Thanks in advance!
  11. #10
    Durango Jedi Master
    Jun 2004
    Fontana, CA
    7,490
    12
    193 times
    You really need to change the plugs. As they wear they increase the load that is placed on the coil packs and helps to wear them out faster. This gets expensive at repair time. Be sure to use some anti-sieaze on the sparkplug threads when you put them in.
  1. E3 Spark plugs??
    By Kid Durango in forum Durango Discussions 1998-03
    Last Post: 10-04-2011, 05:49 PM
  2. E3 Spark Plugs
    By one bad D in forum Durango Discussions 1998-03
    Last Post: 10-04-2011, 06:59 AM
  3. Spark plugs
    By nrk30635 in forum Durango Discussions 1998-03
    Last Post: 05-06-2010, 07:56 PM
  4. Look at these 4.7 spark plugs
    By rayjj in forum Durango Discussions 1998-03
    Last Post: 04-04-2006, 09:19 AM
  5. 4.7 spark plugs
    By Durangoduke in forum Durango Discussions 1998-03
    Last Post: 05-14-2005, 08:28 PM
Search tags for this page
2008 chrysler aspen spark plug replacement
2008 dodge hemi spark plu replacement time
2008 dodge ram spark plug gap
spark plug gap 2004 dodge ram hemi
spark plugs to use in 08 ram hemi
