Rough Idle
Page 1 of 2 12 LastLast
Results 1 to 10 of 19
Thread: Rough Idle
    Durango Jedi
    Mar 2005
    Roanoke, VA
    4,249
    626
    3 times
    Rough Idle
    I've been trying to correct a rough idle and this is what I've done. Cleaned the throttle body, looked inside for any sign of oil (looked OK), changed plugs, NAPA cap & rotor button, Taylor hi-temp wires and I've ran out of things to try. It sits a lot and is hardly ever driven. I keep it hooked up to one of those battery tender's to keep the battery up as I know D's don't like low batteries! Could I have some kind of condensation in the lines causing this? I also put a bottle of Techron in it a while back. If anyone has any ideas, let me know? Thanks.
    2003 Dodge Durango 4.7 4x4
    2004 Dodge Ram 1500 5.7 Hemi
    2014 Toyota Camry SE
    2000 Buick Century
    Grasshopper roguemind's Avatar
    Oct 2007
    New London, CT
    76
    1619
    Check the Idle Air Control valve & Throttle Position Sensor? though you might have done this when you inspected/cleaned the throttle body. If that doesn't do it, search for the hundred other threads about this sort of problem.
    Durango Jedi
    Mar 2005
    Roanoke, VA
    4,249
    626
    3 times
    Yeah, I checked the IAC and it looked OK, but it still it could be bad I guess? Or the TPS as well, I don't know??
    2000 Buick Century
    Aug 2005
    Antarctica
    15,068
    807
    101 times
    rough idle at startup or all the time?
    IndyD
    Durango Jedi
    Mar 2005
    Roanoke, VA
    4,249
    626
    3 times
    It does it most of the time and there have been times when it runs smooth. Kinda strange?
    2000 Buick Century
  7. #6
    Super Moderator tomk's Avatar
    Jun 2004
    Amherst, MA
    10,672
    16
    930 times
    O2 sensors?
    If you can, take a ride with an ODB-II reader that'll give you "live" O2 and fuel-trim readings. You might be able to see what's going West when it starts running rough.
    Be amazed at the friends
    You have here on your trip
    07 JGC Red Rock Limited 5.7L
    And some past Durangos
    de W1PF
  8. #7
    Oct 2007
    New London, CT
    76
    1619
    I'd swap the TPS. I think that's what cured my wandering idle. If memory serves they're pretty cheap? cheaper than o2 senors anyways. There's a way to check the reading on it with a multimeter, but I'm not sure of the readings you need. I wanna say 0.3v at idle and close to 5v at full throttle??
  9. #8
    Durango Jedi
    Mar 2005
    Roanoke, VA
    4,249
    626
    3 times
    I replaced both 02 sensors less than 500 miles ago
    2000 Buick Century
  10. #9
    Aug 2005
    Antarctica
    15,068
    807
    101 times
    Bosch?
  11. #10
    Durango Jedi
    Mar 2005
    Roanoke, VA
    4,249
    626
    3 times
    No, I bought them at the stealer they're Mopar
    2000 Buick Century
  1. Unknown oil leak AND rough idle
    By sw1tch_nut in forum Durango Discussions 1998-03
    Last Post: 04-09-2010, 02:29 PM
  2. Rough Idle and Oil Consumption
    By Beege in forum Durango Accessories 1998-03
    Last Post: 05-26-2007, 12:05 AM
  3. rough idle
    By 1985cj7 in forum Durango Discussions 1998-03
    Last Post: 04-24-2007, 05:41 AM
  4. Rough Idle
    By mickeyd in forum Durango Discussions 1998-03
    Last Post: 01-06-2007, 06:46 PM
  5. Rough Idle - This fixes it.
    By GunTotinD in forum Durango Discussions 1998-03
    Last Post: 07-11-2006, 01:24 PM
Search tags for this page
1999 dodge durango rough idle
2001 dodge durango rough idle
occasional rough idle in 2003 durango
