P0551 Code - power steering pressure switch
Page 1 of 2 12 LastLast
Results 1 to 10 of 14
Thread: P0551 Code - power steering pressure switch
    Mar 2005
    New Hyde Park, NY
    10
    616
    Hey all,
    D's got about ~82k miles on it now, and the check engine light sprang to life a couple of days ago while on the highway. Got to a rest area and saw that the code was P0551. Of course, the first thing I did was check on the forums here to find out what I've gotten myself into. Most said it's probably a faulty connection on the power steering pressure switch. Also that it's best to replace it before it causes other issues like leaking onto the o2 sensor, etc.
    The power steering fluid level was fine and no visible leaks anywhere. So I'm going to follow the wisdom of DOC -- never steered me wrong before. I read it was the easiest fix ever. Rockauto has the part (PSS13) for about $24 shipped. Just wanted to know -- where's the switch located? No one seemed to mention that.
    Thanks!
    2001 White SLT 4.7L
    Durango Jedi Master
    Jun 2004
    Fontana, CA
    7,576
    12
    218 times
    Please, do check the wiring harness for any intrusion of fluid and clean till you don't find anymore. The p/s fluid can wreck your PCM and other sensors by following the harness from the inside.
    May 2004
    ICE COLD NORTH JOISEY
    28,050
    7
    1792 times
    2013 R/T D HEMI
    Definitely get it replaced ASAP because it'll wreak havoc
    Aug 2005
    Antarctica
    15,070
    807
    101 times
    damn 4.7s
    These should help.
    IndyDurango
    Attached Thumbnails Attached Thumbnails P0551 Code - power steering pressure switch-switch_fig1.png   P0551 Code - power steering pressure switch-switch_fig2.png
    May 2004
    28,050
    7
    1792 times
    2013 R/T D HEMI
    I do believe the powers steering switch is the same on 4.7's as well as 5.9's with rack and pinion
  7. #6
    Senior Member Tazdevil's Avatar
    Sep 2004
    473
    69
    3 times
    Just change it its an easy fix.
    2000 4.7 stock motor, 2 inch add a leaf, high flow air filter intake.
  8. #7
    Aug 2005
    Antarctica
    15,070
    807
    101 times
    Quote Originally Posted by FSTDANGO3
    Codes from that sensor go back to the PCM. Nothing mentioned in the guide for the 5.9L? only the lil 4.7l
    I could be wrong, only looked up the 2000 because that's the only data I have, but don't think so.
    IndyD
  9. #8
    Durango Jedi Neil's Avatar
    Jun 2004
    Marlton, NJ
    2,251
    21
    2 times
    It's not engine specific. I believe as Steve indicated above it's a Rack and Pinion sensor. Rack and pinion did came in 01+.
  10. #9
    Super Moderator tomk's Avatar
    Jun 2004
    Amherst, MA
    10,937
    16
    1016 times
    actually it's engine specific, apparently?
    03 FSM:
    A pressure sensing switch (Fig. 6) is included in
    the power steering system (mounted on the highpressure
    line.) This switch will be used only on vehicles
    equipped with a 4.7L V?8 engine and power
    steering.
    What?
    07 JGC Red Rock Limited 5.7L
    And some past Durangos
    de W1PF
  11. #10
    Jun 2004
    Marlton, NJ
    2,251
    21
    2 times
    Damn?wrong about something Well either way it's good for me. My steering box has been leaking for a while. I need to change it this spring. (that's what I said last fall.) I have seen posts warning of the potential problems but I couldn't see any harness in the area. That confirms why.
  1. Code 0551, power steering switch failure?
    By jrinaman in forum Durango Discussions 1998-03
    Last Post: 09-21-2009, 08:48 PM
  2. Check Engine Light Code - P0551
    By byee in forum Durango Discussions 1998-03
    Last Post: 06-04-2009, 10:43 AM
  3. Power steering pressure switch available??
    By 2kDurango4X4 in forum Durango Discussions 1998-03
    Last Post: 06-21-2008, 06:31 AM
  4. P0551 Power Steering Pressure Sensor Circuit
    By Briko11 in forum Durango Discussions 1998-03
    Last Post: 10-31-2006, 05:14 PM
  5. Power steering pressure switch. Check it.
    By zxlwno in forum Durango Discussions 1998-03
    Last Post: 02-17-2006, 05:37 PM
Search tags for this page
code p0551 dodge durango
dodge durango p0551
p0551
p0551 dodge dakota
p0551 dodge durango
