Oil Change. Synthetic Or Regular?
Results 1 to 7 of 7
Thread: Oil Change. Synthetic Or Regular?
    Nov 2008
    6
    1753
    Hi Everyone. My First Post. Basic Question.
    I Have A 99 Durango With 276,000km on it.
    I have been running it on 10w30 and am thinking of changing it over to synthetic.
    Is this a Good Change?
    What type of Synthetic is Best?
    I Love In Ontario. Hot Summers And Cold Winters.
    Aug 2005
    Antarctica
    15,070
    807
    101 times
    99Murder/Redrum99, Welcome to the Durango Owners Club!
    At 171,500 miles, I'd continue doing whatever you have been doing. No real reason to switch at such a late stage in the game.
    With that said, Mobil1
    IndyDurango
    Durango Jedi Silver Ghost's Avatar
    May 2004
    Upstate NY
    2,057
    5
    5 times
    One of the potential problems is that synthetics don't cause rubber gaskets and seals to swell as much as they'd with conventional fluids. That being the case, at your mileage, you run the risk of leaks springing up around the oil pan and valve covers.
    If you intend to switch to synthetics, first use a high mileage semi-synthetic (synthetic blend), then switch to full synthetic. This will help condition the gaskets and seals and minimize leaks. You may still need to snug down on bolts or replace some gaskets anyway.
    Joe
    Joe
    May 2004
    ICE COLD NORTH JOISEY
    28,020
    7
    1775 times
    2013 R/T D HEMI
    Valvoline makes high Mileage synthetic that'll help swell seals.
    May 2004
    Upstate NY
    2,057
    5
    5 times
    Yeah - in the seal business you design gaskets and such so they won't swell (and break down), then the oil folks design a oil/lubricant to swell the gasket so you don't get leaks. The gasket standards are set for a maximum % swell for exposure in various oils (ASTM #1 and ASTM #3 usually) that often have no bearing on the aggressive nature of the oils currently in use.
    If you need an oil that'll swell the gasket, stick with a conventional or semi-synthetic brand. No need to spend big $$ on synthetics.
    Joe
    Joe
  7. #6
    Durango Guru DCDAD's Avatar
    Oct 2005
    Meridian, Idaho
    1,448
    868
    01 SLT,4.7,,In Platinum
    4.56 LSD Front and rear, 545RFE TCM
    Quote Originally Posted by Silver Ghost
    Joe
    My thoughts as well.
    Ron
    2000 R/T Durango patriot blue. Gave to my brother,Gone too.
    2002 SLT+ Black,4.7L 3.55 LSD-Gone
    2001 5.9 SLT+ Gone
    2003 4.7 sport-Gone
    Current Vehicles,
    2001 4.7 SLT 4.56LSD,545RFE TCM, in Platinum
    2002 Volvo S80 T6 (twin turbo) lots of fun to drive. RIP.
  8. #7
    Nov 2008
    6
    1753
    Thanks
    Excellent.
    thanks for the fast responce guys.
    Semi-Synthetic. I"ll give it a try.
  1. Are stick-on wheel weights as good as the regular ones?
    By greendurango in forum Durango Discussions 1998-03
    Last Post: 12-15-2010, 10:30 AM
  2. Regular maintenance
    By JWhirl06 in forum Durango Discussions 1998-03
    Last Post: 07-23-2009, 07:09 AM
  3. Looking for basic suspension upgrades, regular maintenance
    By 02Rango Ohio in forum Durango Discussions 1998-03
    Last Post: 11-02-2008, 04:33 PM
  4. Do you run premium or regular in your 4.7
    Last Post: 01-15-2007, 04:16 PM
  5. To change or not to change the tranny fluid?
    By viperbob in forum Durango Discussions 1998-03
    Last Post: 11-22-2006, 11:43 AM
Search tags for this page
1998 dodge durango synthetic switch
can i use full synthetic oil in my 2002 dodge durango
can i use semi synthetic oil in 2002 dodge durango
do i need a semi synthetic oil for 2002 durango
does dodge durango meed synthetic oil
