Fixed my speakers and replaced the turn signal relay.
Results 1 to 5 of 5
Thread: Fixed my speakers and replaced the turn signal relay.
    Senior Member
    Aug 2005
    Tucson, AZ
    326
    795
    This is probably not a big deal to most of you but I'm pretty happy about the repairs I made.
    I removed my blown speakers and found that the foam surrounds had just separated from the speaker frame. No holes or anything. So I did the rubber cement fix. I figured I had nothing to loose. I went over the surrounds several times until I had the rubber cement built up pretty good. I let them dry for a while and then reinstalled. Speakers sound great! Bass is back and no rattle/buzz.
    Another problem - turn signals have been freezing and not flashing. It doesn't happen all the time but it's starting to get annoying. I found that the problem happens with either the turn signal stalk or with pressing the 4 way hazards button. So I figured it had to be the relay and not the switch. I bought a new green relay from the dealership. Part # 56021915-AA for $39.15. It was a pain to get up under there and pull the old one out. A bunch of wires are blocking it but I did remove the old one and install the new one. It's flashing great now. I'll have to wait and see if the freezing problem is fixed but I'm fairly certain it'll be.
    2012 Dodge Durango SXT, 3.6, AWD
    2000 Dodge Durango SLT+, 4.7, 3.92, PT4WD
    2008 Dodge Magnum R/T, 5.7, RWD
    Durango Jedi Neil's Avatar
    Jun 2004
    Marlton, NJ
    2,251
    21
    2 times
    Good you got thinggs fixed. FYI a flasher from the parts store is $14 for anyone else that needs one.
    Senior Member
    Aug 2005
    Tucson, AZ
    326
    795
    Quote Originally Posted by Neil
    I didn't realize they sell the same relay at the regular auto parts stores. Oh well, I'll know for next time.
  4. #4
    Administrator skitzo.d's Avatar
    Jul 2004
    Northern GA
    5,591
    46
    113 times
    2004 Ram 2500 4x4 Quad Cab and '42 Dodge Dually
    good you got that stuff fixed. I ended up just replacing my speakers.
    it's always better when you can fix the D yourself. I wish I could do my own tranny, but alas, I'll have to pay?
  5. #5
    Senior Member
    Aug 2005
    Tucson, AZ
    326
    795
    Quote Originally Posted by skitzo.d
    I know what you mean. I had an exhaust leak due to broken exhaust manifold bolts. That one I had to pay to have fixed.
  1. Turn Signal Issue
    Last Post: 08-14-2011, 01:32 AM
  2. Turn signal problem
    By IndyDurango in forum Durango Discussions 1998-03
    Last Post: 06-03-2010, 06:31 AM
  3. Right Turn Signal
    By Machine in forum Durango Discussions 1998-03
    Last Post: 07-20-2008, 12:24 AM
  4. Fast Turn Signal
    By EyeSpy in forum Durango Discussions 1998-03
    Last Post: 11-01-2005, 10:41 AM
  5. turn signal problem
    By ShelbyStyle98 in forum Durango Discussions 1998-03
    Last Post: 03-10-2005, 12:42 AM
Search tags for this page
1998 durango turn signal relay
how to fix speakers for dodge magnum
turn signal relay 99 dodge durango
