Durango tripped code P0442. EVAP system small leak
Page 1 of 8 123 ... LastLast
Results 1 to 10 of 72
Thread: Durango tripped code P0442. EVAP system small leak
    Senior Member 02Rango Ohio's Avatar
    Oct 2006
    319
    1263
    I reset it with the the scan tool but it comes back on about every 100 or so miles.
    I just replaced the gas cap with a locking gas cap about a month ago and I also might be guilty of refueling with the truck running.
    Where should I start looking? Which vac lines are associated with this code?
    Thanks again.
    May 2004
    ICE COLD NORTH JOISEY
    27,988
    7
    1771 times
    2013 R/T D HEMI
    Did you use a Mopar locking cap? If not, put the stocker back on.
    Next under the D there's a vacuum canister with several hard plastic lines coming off it and it's common for some of those to split and cause a minor evap leak.
    Aug 2005
    Antarctica
    15,070
    807
    101 times
    +1
    Start with the simple by eliminating the last changed variable.
    First, put the stocker cap back on and see what happens. Second, check the lines to the evap canister under the D. Let us know from there if those don't do it.
    IndyDurango
    Durango Guru Don Fox's Avatar
    Sep 2004
    Oxford, Ohio
    1,205
    100
    40 times
    Ok guys:
    I too have the dreaded PO442 code, and have looked pretty exhaustively for the cause without success.
    Today, I spent an hour or so removing the battery tray to make sure none of the lines nearby or underneath were cracked.
    All are good to go from what I can see.
    If I erase the code, the CE light will stay off for a few days, then when I make the first start of the day one day it'll come on when I'm a thousand feet or so into the trip.
    Already took care of the common cannister hoses several months back when I got te PO456 code.
    I guess it could be the gas cap, as Lord knows we Durango owners are well aquainted with removal/installation of that bugger.
    Sep 2004
    Oxford, Ohio
    1,205
    100
    40 times
    Guys and Gals:
    Still getting the CE light and attendant P0442. Looked over all hoses I can fine including cannister and under the battery tray. All appear to be in good shape.
    Now, am getting the P0442 along with the P0455 large leak.
    Please scratch your proverbial brains, and advise on what to do next.
  7. #6
    May 2004
    27,988
    7
    1771 times
    2013 R/T D HEMI
    Did you put a new Gas cap on to try it and a Mopar one will work best.
  8. #7
    Sep 2004
    Oxford, Ohio
    1,205
    100
    40 times
    Hi Steve;
    Haven't done that yet. I guess I'll give the dealer a call, and see how many children they want for one??
  9. #8
    May 2004
    27,988
    7
    1771 times
    2013 R/T D HEMI
    If at some point the cap was dropped pretty good it could be a problem
  10. #9
    Sep 2004
    Oxford, Ohio
    1,205
    100
    40 times
    My cap has the OEM tether. it has never been more that a few inches from the filler neck.
    Dodgeparts.com wants ~$13 for one.
  11. #10
    Durango Expert 20durango03's Avatar
    Sep 2008
    Denver, Colorado
    539
    1742
    2002 Durango SLT 4.7
    CAI. H/O Cams. HID 6K. Led Tail Lights. After Market Head Lights. Electric Fan Setup.
    When I first got my Durango it was throwing that code also, I had fixed it by getting under the Durango and next to the air canister I replaced the lines going to it, I haven't had the problem since then. If that helps any
    2002 Dodge Durango SLT+ 4X4 V8 4.7 144K
    LED Taillights + 3rd. Hids 6000K, Aftermarket Head Lights, H/O Cams. CAI. 180 T-Stat. Mark 8 Electric Fan.
    2000 Dodge Durango SLT+ 4X4 V8 5.9 135K
    Fastman TB 52 MM. CAI. LED Taillights + 3rd. Aftermarket Headers. HID Headlights.
  1. EVAP leak
    By Cristo in forum Durango Discussions 1998-03
    Last Post: 10-03-2014, 07:20 AM
  2. P0442 Evap Leak Monitor Medium Leak Detected
    By mickeyd in forum Durango Discussions 1998-03
    Last Post: 07-26-2012, 12:45 PM
  3. P0456 Evap Leak Monitor Small Leak Detected
    By qwassy111 in forum Durango Discussions 1998-03
    Last Post: 06-04-2011, 08:45 AM
  4. EVAP system, big leak
    By Durang00 in forum Durango Discussions 1998-03
    Last Post: 05-28-2007, 05:45 PM
  5. EVAP Error Codes?P0442, P0455//01 D SLT, 4.7
    By eelsfoot in forum Durango Discussions 1998-03
    Last Post: 08-22-2005, 01:49 PM
Search tags for this page
2003 dodge durango code p0442
2003 dodge durango small evap leak
p0442 dodge durango
p0442 durango
po442 dodge durango
